Cash,
You will probably get more responses on Tuesday after folks get back to work and spend work time on the internet . . .
Will you be running cooling ducts? If not, the quick answer is . . . the rotors (fronts at least) will be trashed anyway after the track event from the heat and will be beyond saving so it won't matter.
Between heat cracking, grooving, and pad material transfer you may not want to keep those rotors so I would be looking for the best replacement deals now . . . especially if you plan to go back to street pads.
More seriously, the specs for my 2001 Mustang are in the same ballpark and Ford says to do any machining on the car. I've never looked for on the car rotor turning.
Have you seen this article?
http://www.stoptech.com/whitepapers/war ... s_myth.htm
Spending Saturday afternoon measuring runout beats lawn mowing, refrigerator door hinge cam replacement, and van headlight plastic adjuster replacement.
