Wes,
Wes Eargle wrote:
http://www.racingbeat.com/resultset.asp?PartNumber=22000
http://forums.corner-carvers.com/showthread.php?t=15972
You still have to lock the flywheel down with this:
http://www.racingbeat.com/resultset.asp ... mber=22001
when doing it manually which can be made as described in my previous post...
The 2 1/8" socket on a breaket bar works fine (and I think a better investment in tools since you can use the socket on an impact, too).
In fact...a breaker bar is sometimes the only way to crack open the bolt on the other end of the motor/eccentric shaft...that bolt has kicked the ass of the same over 650 ft-lbs of reverse torque impact wrench TWICE in the past few months only be overcome by body weight on a breaker bar. They put a ton of loctite on those fasteners!
I had one that wouldn't come off with 6-feet of extension on the breaker bar - it broke the breaker bar and we even torched it and subjected to just about any torture we could to get it off to no avail. The motor was never opened, ended up being sent back as a core.
Thanks goodness for the Craftsman guarantee replacing my breaker bar.
