I wrote to Hoosier just to see what they'd have to say. It is somewhat educational. Their response is below. I also left my original question to them at the end of this article.
Miles,
Thanks for writing and for your concern of recommended air pressures. I believe most all of our tires, especially DOT approved tires will have the Max 44 psi stamped or molded into our sidewall. This pressure recommendation is really for tire mounters not to exceed this pressure when mounting a tire. More often than none, tire mounters will have difficulty mounting a tire and exceed this pressure to seat the bead of the tire. This pressure has nothing to do with operating pressure. Your 44 psi front and 42 psi rear sound just right for your car and for autocrossing. On some road courses, in the heat of California or Arizona sun, exceeding 100 degrees air temperature, cars may experience 46 to 48 psi hot.
There is no danger of the tire exploding from running higher air pressure on an autocross course. The main problem with running pressures at 65 psi +, is the car will not handle properly, or not stick to the course and cause the car to spin out. Another attribute of running higher air pressure is wearing the tire out quickly in the center, because of crowning of the tire.
I would strongly suggest not running that high, expecially 65 psi + for possible wheel failure. If you could pass on to your competitors to keep their air pressure below 50 psi, that would be appreciated. I cannot imagine anyone being competitive at those high air pressures. The weak point between the wheel and tire is the wheel bead flange. The tire bead will actually push out as the pressure increases inside the tire and then bends the wheel flange which causes a quick deflation and dangerous situation.
I hope I have helped.
- Jeff Speer, Hoosier Racing Tire
----- Original Message -----
To:
info@hoosiertire.com
Sent: Monday, October 13, 2003 5:10 PM
Subject: Unsafe Tire Pressures???
Dear Hoosier Tire,
I autocross with a club in NC. Personally, I run a 91 Corvette. With Hoosier R3S03s, I've found that cold tire pressures of about 44 in the front and about 42 in the rear work well on asphalt. On a concrete surface, I have found that bumping that up 2 psi is about right.
I recently found that some of my fellow autocrossers are running much higher pressures. High enough that as a mechanical engineer, I became really concerned from a safety standpoint. Some of these guys are running 60 to 65 psi and I even heard one guy talking about 70 to 75 psi in his Hoosiers!
I know the pressure stamped on the side of the R3 and A3S03 tires is Max 44 psi, but what I want to know is at what point does exceeding the maximum pressure become a safety risk? It's hard for me to believe that autocrossing on a tire with a 70 psi pressure is safe. Is it? As a reference, what is the typical "burst pressure" for a tire? Are larger tires more likely to burst at a lower pressure than smaller tires?
If these pressures are the safety risk I think they are, I'd like for you to give me some kind of data or response that I can share with my friends to convince them that 70 psi is just plain nuts. If I'm wrong though.... please tell me that too!
Thank you,
Miles Beam, P.E.
Autocrosser in NC
