Are there any Honda CRX Si (1988) cylinder head experts out there?
I got a chance to adjust my valves today and ran into a potential snag. I bought the CRX with 235k miles on it and I really don't have any idea of the history of the car. Something in the head was ticking like a time bomb (or a Miata
) and I assumed it needed a valve adjustment. Sure enough, most of the lash tolerances were *way* out and once I set them where they should be, the car seems to idle like a champ. I didn't get a chance to test drive it yet but it seems much more responsive just blipping the throttle.
The potential problem is that on one of the exhaust valves on the #4 cylinder, the adjustment screw had to be nearly bottomed out to get the lash within spec. All of the adjustment studs sit about 1/8" above the set nut (gotta be a joke in there somewhere) while the problem child mentioned above sits nearly 1/4" *below* the top of the set nut. If it was any lower there wouldn't be enough thread within the nut to tighten it properly.
I'm guessing this was the valve that was ticking so loudly. While the tick is totally gone, is this going to cause me a problem in the future? Any idea what would cause this one valve to be so far out of adjustment? About the only thing I can think of is that the spring has weakened over time and is sagging. I can't really see and other signs of physical damage to the rocker assembly but it wouldn't take much to throw it off I imagine.
I'm currently looking for another head I can rebuild in my spare time but it will probably take a couple of months. Well, unless of course I have to do something about this immediately.
Any ideas?
Thanks,
