 Post subject: First welding project!
PostPosted: Thu Oct 02, 2003 1:35 am
Well, I managed to break a bracket on my new rear swaybar ... turns out I installed it wrong and the bolt head was offset in the hole.
Great, I thought tonight when I discovered it with a loud "clunk" on right turns, now I need to go order a new one. :(
Wait! I have a welder! Sure, it's a crappy ancient AC stick welder, but let's get some beer and try it out! As you can see from the picture below, thankfully this is not a strucutral application. I suck at welding.
I figure if I can learn to weld on this piece of junk, I will be able to use anything. Just thought I'd share. :)
The problem:
The solution:
