Kevin is still the only one I know that says Azenis are safe in the rain.
If you will look at some of my old posts on the Listserv, you will see that I was one of those giving the Azenis a hard time about it not being a legitimate "street tire", about they are dangerous in the rain, etc. I generally have changed my tune…
I had been running the Azenis 100% of the time until very recently. While I would not recommend them as a wet weather tire, I do think they are “safe” if you are aware of their limitations. With full tread they are pretty good unless you are driving into pools of standing water at higher (interstate) speeds. When you do, you just will not have the confidence that you will have with a tread that evacuated the water like a good all weather tire. As they wear, they will eventually get progressively worse in deep water.
I drove mine until about mid/late-summer when we started to have some decent rain. The tires were VERY worn (down into the casing on the inside edge of two tires due to front toe and camber settings) and I started to get wheel spin in 4th/5th gear on the interstate in heavy rain. I like to think that my elite wet driving skills kept me out of trouble that day. But it was probably luck that kept me from stuffing the car into a bridge abutment. Either way, because the pucker factor was VERY high
I decided it was time to put them away and switch back to my stock wheel/tires.
So, if you pay attention to the conditions and watch tire wear they are totally acceptable for an enthusiast driver IMHO. BUT, I would not put them on a car that was driven by someone who didn't understand the limitations of the tires. You WILL get better wet weather performance out of MANY other tires.
With the new tires looking to have an even more "rain" friendly tread pattern (thank you for the new center channels!), I will have no reservations about putting these back on the car and driving them all of next year. Since they most likely will not be available until the spring, I can dodge the snow/ice issue as well.
