 Post subject: Old gasoline - what to do with it?
PostPosted: Mon Sep 20, 2004 12:16 pm
I've got 2 gallons of 3+ year old gasoline I drained from an (Karl's old) MGB. Anyone have ideas about what to do with it?
I know I can take it to the Wake county hazmat disposal, but that's really inconvenient. Or I could make some Molotov cocktails, but I don't have any enemies that require that degree of violence.
Safely burn it? Put it out and let it evaporate? Kill weeds? Dump it in the suburban at the next fill-up? (40 gallon tank!)
 Post subject: Re: Old gasoline - what to do with it?
PostPosted: Mon Sep 20, 2004 12:25 pm
You gotta race the truck
Run it through your lawn mower. Mix it half and half with regular till you use it up. Lawn mowers are much more forgiving to bad gas
91 Jetta GLI STS/DSP 111
85 Porsche 944 ASP 11
PostPosted: Mon Sep 20, 2004 12:43 pm
I'd Shake it up and pour a bit into a jar first. See if the condesation built up enough to have a noticable amount of water. My friend Will got stranded because he poured old gas into his boats tank from an old broke down truck of his, and it had A TON of water in it.
2005 GMC Sierra
1991 318is Garage Ornament
PostPosted: Sun Dec 05, 2004 9:39 pm
If there is water in it, I would not recommend using it in a lawn mower. Water will collect in the float bowl and then you will have to disassemble and drain it.
For small amounts, I bleed it into my used oil and take it to an oil disposal site or a Jiffy Lube. Otherwise, you can deliver it to a county facility that accepts old chemicals, paint, motor oil, etc.
Dave Phillips
78 Porsche 911 SC
PostPosted: Mon Dec 06, 2004 1:46 am
I decided to burn my neighbor's house down using the old gas. His dog has been sh!tting in my yard. That'll teach him. Maybe I should just light the dog on fire?
PostPosted: Mon Dec 06, 2004 10:21 am
try putting some in a paint gun and hooking it up to your compressor and have fun with a flame thrower..
PostPosted: Tue Dec 07, 2004 11:33 am
Most of the tracks have dedicated disposal barrels for oil, antifreeze, and gasoline. You could hang on to it till you head to the track, if dropping by the hazmat disposal is inconvenient. Not as much fun as some of the other suggestions, but perhaps a little more environmentally responsible. (Now if I could just attach the video clip of Paul Tuttle, Sr. from Orange County Choppers throwing gasoline on the yellow jacket nest outside his shop...)
Marvin McBride
Spec Miata #62
