Ok, I started working on the 90 crx again and I was finally successful in removing the drivers side axle. The passenger side is not cooperating and I need ideas to remove the ball joint.
See the pics that show that I broke the pin in the remover tool, notice the pin is sheared off and the stress it went through. Pics are blurry, but they'll give you an idea.
I've put nearly a can of PB Blaster on over the last couple months, I've had the pictured ball joint remover as well as other gear-type pullers on it for extended lengths of time and this one will not budge. I'm about to get the grinder out!!!
The tool....
The broke pin...
Phil
