 Post subject: Lugnuts
PostPosted: Mon Jul 12, 2004 9:57 pm
I'm "considering" using a set of spacers for autocross only. How many threads of the lugnut need to be on the bolt, before I need to consider getting longer lugs?
 Post subject: Re: Lugnuts
PostPosted: Mon Jul 12, 2004 10:20 pm
For the DSP car? 1/2 of a turn should be fine.
:lol:
From http://www.tirerack.com/wheels/tech/torque.htm
Size of Bolt or Stud - Mininum Number of Turns
14x1.5mm - 7.5
12x1.5mm - 6.5
12x1.25mm - 8
1/2" - 8
9/16" - 8
PostPosted: Mon Jul 12, 2004 10:55 pm
Ha, b/c you need so much help in DSP. Especially now that the corrado's gone :)
www.ncvw.org
1997 BMW M3 3.2L - BS for now
PostPosted: Mon Jul 12, 2004 10:59 pm
12x1.25mm - 8
ARGH, missed it by 1.5 threads. Oh well, thanks for the link.
PostPosted: Tue Jul 13, 2004 9:55 am
Get some 2.5 inch studs from Moser. 8)
2005 GMC Sierra
1991 318is Garage Ornament
PostPosted: Tue Jul 13, 2004 1:03 pm
Mr. Nice Guy
I've always heard 5 turns before torquing. That worked great when we ran in DS in the WRX. I actually had about 4.5 turns before torquing.
For road racing I would feel comfortable with more, for autox, that was plenty.
-Tom
PostPosted: Tue Jul 13, 2004 2:25 pm
Well, I ordered more wheels/tires today, and the TireRack representative said that the list that is posted is the 'ideal', but 4.5 to 5 turns for any lug stud is more than sufficient. Their worry point is anything south of 4 turns. Here I was worried that my 5 turns with 1/4" spacers was getting dangerous :) - AB
PostPosted: Tue Jul 13, 2004 2:32 pm
I put my wheels on crooked to increase negative camber. i get plenty of turns on the top lugs, but the bottom lugs are only on there about 2 turns. It seems to be working for me :)
PostPosted: Tue Jul 13, 2004 3:17 pm
I was using that method to adjust toe. I didn't know I could do it for camber too! Wooo!
PostPosted: Tue Jul 13, 2004 3:23 pm
Since my Formula Ford uses center lock wheels (only one lug nut), I have to use either a tapered spacer or a lugnut which has a tapered surface. Taper in two directions for camber and toe.
