 Post subject: I need to borrow an impact gun
PostPosted: Mon Feb 15, 2016 4:43 pm
Does anyone have a high quality impact gun I can borrow. (air powered) I need to bust off a hub nut that is being very difficult and neither my battery powered gun or my cheap air tool is working.
Thanks
ROb
2005 Mazda 6 Wagon
 Post subject: Re: I need to borrow an impact gun
PostPosted: Mon Feb 15, 2016 4:58 pm
I have a 1/2" breaker bar with a 3' cheater if you wanna borrow it.
PostPosted: Mon Feb 15, 2016 5:12 pm
The breaker bar and cheater work best
2004 C5(415whp,390ft/lbs),
1997C5,1997Trans Am, 1986 C4,
PostPosted: Mon Feb 15, 2016 6:25 pm
Tried the breaker bar and heat. No luck..THe other side came off no problem. I've been blasting it about 2X per day so hopefully after a few days...
2005 Mazda 6 Wagon
PostPosted: Mon Feb 15, 2016 6:29 pm
I've got both a pneumatic and electric. No clue how far I am from you...
PostPosted: Tue Feb 16, 2016 5:01 pm
I've always used a breaker bar and "cheater" 3-4' pipe on the Miata hub nut. I have never had any luck with an impact gun. The last time I removed one, I bent the pivot connection on the bar slightly to where it binds. Those nuts are on there tight!
PostPosted: Tue Feb 16, 2016 5:50 pm
You need a cheater pipe...a big one. I got some galvanized pipe from Lowes and it works great.
http://www.lowes.com/pd_24006-76064-104 ... 57850&pl=1
Im in Clayton near the airport if you wanna come by and borrow it.
PostPosted: Tue Feb 16, 2016 10:03 pm
I'm pretty sure I almost had the car off the jack stand when I finally popped one of the rear ones on my car. The hard part is getting the axle stub out of the hub. If the nut is welded on there that hard the whole thing is likely a write off. Be careful to not mushroom the end, pounding on it with a hammer is the wrong way if it doesn't go quickly. Bring it to a shop with a large (20t+) press.
PostPosted: Wed Feb 17, 2016 11:30 am
Just pull the axle and bring the knuckle + axle to a shop. If it doesn't want to come out with 10-15t on it, the axle's a write off.
PostPosted: Wed Feb 17, 2016 12:31 pm
Seems I remember successfully using a 3 jaw puller on axles, with anti-seize on the splines for re-assembly. Getting the bearing out of the knuckle requires a 20 ton press for sure...plus penetrating oil...and heat...and hammering...and time :)
PostPosted: Wed Feb 17, 2016 1:31 pm
To Jordan's comment, heat is your friend here. I was having some serious issue getting the front struts done on the old mazda 3 I had. I had to upgrade to mapp gas to get the job done. The propane wasn't getting hot enough quick enough.
PostPosted: Wed Feb 17, 2016 1:35 pm
I was trying to get the transmission bracket to diff bolts out on mine when pulling the motor and pretty sure I twisted one of the bolts. I decided to stop and leave it be before I snapped one off and made a giant headache for myself. I guess the brace is just stuck on there forever now lol.
2017 Autocross Chief of Tech
2000 E Street Miata
2015 Fiesta ST (Wife's ride)
PostPosted: Wed Feb 17, 2016 2:53 pm
I have axles. I literally can't get the nut loose. The right side one came off fine. Trying to not have to buy hubs and wheel bearing however, the more heat I have to use.
2005 Mazda 6 Wagon
PostPosted: Wed Feb 17, 2016 3:06 pm
You're right there, might as well.
https://www.youtube.com/watch?v=RQHyjr-ybJk
PostPosted: Wed Feb 17, 2016 6:48 pm
Rob,
I've got all kinds of stuff you can borrow. 18v Snap on 1/2" impact, 1/2" air impact, 24" breaker bar, cheater pipes, etc.
I'll agree with the idea that you need leverage here to crack it loose, but sometimes hitting it with a strong impact does the trick.
Bret
