I have seen that before. It would be interesting to have a thread full of "tricks". Some that come to mind...
1. Grease gun to remove stuck piston in caliper. install a zerk fitting on the caliper and then use a grease gun to pump in grease to push out the piston. You can use compressed air to the the same, but you can also create a cannon that will launch the piston when it comes loose.
2. Similar to above... The bread and pilot bearing trick (google if you don't know this one)
3. Using a small socket (or some other tool) to pop loose the ball joint from Honda front suspension (not sure if this works with recent models). Remove castle nut, then use a jack to compress the spring/suspension a bit. Slip a small socket into the gap created between the hub and lower arm, lower the jack (which wedges the socket between the hub and lower arm and puts pressure on the friction fit for the ball joint. And then... pop! it's free.
https://www.youtube.com/watch?v=hJR77aN-MDkRichard
