Chris Halweg wrote:
Chad Culbertson wrote:
It's running well now and staying cool. I think a couple issue were working against me, and I learned from them for sure.
I think initially I did in fact have some trouble getting the air out of the system, and drilling the 1/8" hole in the t-stat helped with that. The other issue which I have yet to resolve is that the gauge in the cluster is reading high. I connected to the OBD port and checked the coolant temp there and it was steady around 197 which is perfect since I put in a 195 t-stat. I let it idle for probably 20+ minutes while I put air in the tires and the spare and it never got hot even with the hood closed.
So, my official diagnoses in why it died is likely a bad fan clutch, you could stop it with your hand no problem. It has an electric fan which should cut on once the ECU sees a certain temperature so I probably need to test that somehow, not quite sure how though. Just the electric fan might not be enough to keep it cool during summer heat idling in traffic though, so it likely still had a lot of overheats which lead to the cracked head. Or perhaps the head cracked for some unknown reason, the head gasket was perfect, so who knows.
Either way, hopefully it will provide me with plenty of miles of service now, I think I'm about 1200 bucks into it now, so still not too bad. It still needs a head liner and some other odds and ends fixed but engine wise it should be all set after an oil change.
The electric fan should come on when you turn on the air conditioning and run constantly.
Yeah, it does, it cuts off/on when the A/C compressor cycles, so the fan is fine.
Thanks for the reference on the headliner, for that price I might let somebody do it for me, I was going to try and tackle it myself. I have done one before in an 89 Cherokee, although my great uncle helped me back then, he did interiors in classic cars.
