BenjaminGuardiola wrote:
I don't want to thread-jack, but can someone share more details about tire life with these?
I destroyed a set of 340TW tires after about 12 events and 1 driver. I did not understand tire pressure and murdered them at novice school.
Now that I have an extra set of rims, I am hoping to step up to the seemingly much faster 200TW.
Is it reasonable to expect 2 years of THSCC events with 1 driver?
There's no easy answer to that question, but one thing to think a lot about (as a relative novice?) is how you are actually using your tires. Think about the slip angle versus lateral grip chart and how in the ideal situation you'd like to stay just to the left of the peak or in the peak area. Look at the example chart below which plots lateral load (cornering force) on the y-axis and slip angle on the x-axis. Let's assume for discussion that we're looking at the front tires for a moment.
Now go to the level on the y-axis that is about 90-95% from the peak of the chart and mentally draw a horizontal line across the chart. Note how you can generate the same cornering force at two different levels of slip angle (where the horz line intersects the curve in two spots). However, being on the right side of the peak, which of course requires a good bit more steering input, you are: (1) creating significantly more tire wear for the same grip level, and (2) have left zero room for error in that curve (since if you need *more* grip at that point, more steering input just reduces grip and you have to slow down to get back over on the left of the peak).
Sorry for the long-winded reply here. I'm just trying to make the point that some drivers almost always drive over the peak of that curve as they've come to believe that it's "faster" since it is more exciting to deal with the car in that region of grip or lack thereof. Hence you could do a tire wear test running 500 times through a sweeper corner with two drivers, two cars, achieving identical times through the corner for the entire test, but one driver manages to wear out the tires 30% faster...
