BenjaminGuardiola wrote:
I don't have a manual. I was going to lean heavily on miata.net tutorials.
Car has around 85k on it. So I am in the ballpark of needing this done even if there was no issue.
Here is what I ordered for the job.
Mazda: Head Cover Gasket, Front Crank Seal, Intake Cam Seal, Exhaust Cam Seal
Gates: TBK, WPK, Thermostat, Belts
I know I will need oil, filter, and anti-freeze. I already did the fuel filter and spark plugs.
TBK and WPK = Timing belt kit and Water pump kit? If so good. Also, unless the Timing Belt Kit comes with it, you will want to add idler and tensioner pulleys to that list. They may not be making noise yet, but they will be soon if not replaced. Out of curiosity, what year is the car?
I never mark anything when replacing the belt. Just line up the marks before removing the old belt, the cams will move a little when you remove the gears to replace the seals, but keep a boxed end 14mm wrench on hand once you are ready to install the new belt. Snap a picture of the orientation for the cam gears before removing the old belt if you are unsure. For the early cars and IIRC the 01+ cars use the same pulley for both intake and exhaust. Going off my memory here, so someone correct me if I am wrong but, the (I) lines up with the intake cam dowel on the intake cam shaft and the (E) with the dowel on the exhaust cam. You will use the (E) mark on the intake cam gear to align with the mark on the intake side and the (I) mark on the exhaust cam gear to align with the mark on the exhaust side. Seems backwards, but it will make sense once you are in there.
To install the new belt, lock the tensioner pulley bolt down in the full slack position (spring tight) (14mm) start from the crank noting that the marks on the crank gear and water pump housing (12 o'clock position, TDC) are lined up. Work the belt around the idler pulley (left side pulley) keeping moderate tension on the belt, enough to keep it tight, but not enough to move the crank. Check alignment of intake cam and use other hand as necessary (with 14mm boxed end wrench) to maintain alignment as you work the belt around the cogs of the intake cam gear. Maintaining moderate tension on the belt, move boxed end wrench to exhaust cam gear (also 14mm) maintain alignment of exhaust cam gear while working the moderately tensioned belt around exhaust cam gear. While maintaining tension on the belt, move boxed end wrench to tensioner bolt and loosen it until the tensioner is pushing against the belt (14mm (see the trend
thanks Mazda engineers!)). Rotate crankshaft 1 7/8 turns so the mark on the crank gear lines up with the mark to the left of TDC mark on the water pump housing around the 10 o'clock position. Tighten tensioner bolt, rotate crankshaft and recheck alignment. All of this takes around a minute, maybe two.
I typed this out not sound cocky, but in hopes of saving you some of the hours it took me to learn this technique and to reassure you that it is not a very difficult job
Post up here if you have any questions during the job and good luck!
