Ok, I have been battling a braking problem for sometime now. Here’s what happens:
Street: Firm pedal, great braking feel, can lock ‘em up at will with my Bobcats. Nothing to see here, move along….
Autox: Firm pedal at the line, but anytime I run it hard into the boost (ie running 2nd gear out), I go to hit the brakes and the pedal goes almost to the floor. You get braking power but it startles the hell out of you and its not what I would term “desirable”
Track: Only noticed loosing the pedal at all braking after the front a back stretches. I didn’t wind it out to redline like I do autoxing. It wasnt “that” bad and it didn’t happen every time. Still not confidence inspiring…
What I have done to fix it:
Bled system 1398429857930589 times, Valvoline stock had to increase a few bucks from my brake fluid purchases
Stainless Steel braided brake lines
2 New Master Cylinders
2 different brake boosters
2 different vacuum hoses from intake manifold to brake booster (There is a valve in the vacuum hose that holds all the pressure my compressor will throw at it, its supposed to let the vacuum in and not let it out, it seems to be working fine).
Rebuilt all four calipers August of 03
I’m stuck here. I’m thinking of buying new Calipers all the way around. Rebuilding them seemed to be the only thing that helped any at all. I just hate the throw parts at a problem I don’t know will solve the problem. I know it certainly wont hurt to replace the 13 year old calipers on the car now.
Any thoughts? Solutions? I just knew that replacing the vacuum booster would do the trick but alas, it didnt. <-- That was the last thing I tried...
