Michael Westerfield wrote:
DickRasmussen wrote:
shawnwhipple wrote:
I'm thinking about changing the brake pads on the BRZ and I wondering if anyone can recommend a brake compound that will work well for autocross/street use. Ideally it will have high friction in the low to mid temp range and low dusting.
You might check with Sam Strano to see if he still recommends Ferodo DS2500. They were fine on my CM car after years of running Hawk HPS. Both were low dust and worked fine cold. I was looking for a "little" more bite compared to the HPS and I'm not sure I got it (hard to tell with the extremely short CM braking zones
) Certainly no negatives compared to HPS.
http://www.stranoparts.com/partdetails. ... ModelID=36http://www.essexparts.com/shop/brake-pads/ferodo.htmlDick, did you have any trouble with deposits? I used to run these on my prelude at hpde and they would always ruin a new set of rotors after a weekend. The vibration after a weekend was terrible. I don't recall how much they dusted.
Mike,
Which pads did you have deposit problems with, HPS or DS2500? I didn't have any deposits with either but a FF autocrossing barely gets any heat into the brakes even with fairly close together runs at an EVO TnT.
FF road racers from Australia like the DS2500's by the way. I don't know if any US FF guys use them.
My 2012 sure gets heat into the oem non-Brembo brakes with back to back runs at an EVO TnT. Enough that the brakes smelled and I could see heat waves.
