 Post subject: Machine Shop?
PostPosted: Thu May 23, 2013 4:00 pm
Can anyone recommend a machine shop for something minor? Preferably close to Chapel Hill, if such a thing exists...
Thanks!
'93 Subaru Legacy DIRTBOMB
'98 BMW M3
2013 Rallyx Co-VP
 Post subject: Re: Machine Shop?
PostPosted: Thu May 23, 2013 4:43 pm
Don't know of anything in the Chapel Hill area, but for engine machine work of any kind- I always use and recommend CHS (Cylinder Head Specialties) in Wake Forest.
What sort of machine work do you need done? Might be a "regular" shop that could do it....
PostPosted: Thu May 23, 2013 5:05 pm
It need a hole enlarged in a very thick metal part, and its too big for a drill bit or die grinder, and too small for a angle grinder. I think a qualified machine shop would save me from screwing it up any more and would have the necessary equipment.
'98 BMW M3
2013 Rallyx Co-VP
PostPosted: Thu May 23, 2013 10:40 pm
I've been happy with Fabco Industries, but they're behind Performance Chassis in Cary.
PostPosted: Fri May 24, 2013 8:56 am
My experience has been to stay away from automotive centric machine shops for this type of work. If you are not asking them to turn a brake rotor, work on a cylinder head, or any of the other common things like that, they either claim they don't have the equipment to help you, not setup to do it, or more likely don't care to mess with your small task.
Richard
PostPosted: Fri May 24, 2013 9:06 am
It's been a long time, but I used a shop next door to Carolina Automasters for some one-off machine work. I was fitting disk brakes to a car that originally had drums, and the rotor hats would not clear the flanges on the rear hubs. They were able to mount the axles on a lathe and cut the flanges down. Did a great job at a reasonable price (charged about 1 hour of labor). It wasn't hard, but it was not ordinary work either.
PostPosted: Wed Jun 05, 2013 2:12 pm
T. Hoff in Raleigh may be able to help.
If you just need a hole enlarged, would a drill press with the right bit be appropriate, or do you need a chamfer or something put on it?
2004 Subaru Forester XT
1992 Sunburst Mazda Miata
2000 Xterra SE
PostPosted: Wed Jun 05, 2013 2:35 pm
Thank you everyone for your suggestions. I ended up buying a Harbor Freight die grinder and high quality burr and it ate through the steel like butter. Unfortunately, I was wearing a t-shirt, and the tiny metal shards impaled themselves in my forearms. :-(
Ouch!
'98 BMW M3
2013 Rallyx Co-VP
PostPosted: Wed Jun 05, 2013 3:28 pm
The worst part had to have been listening to Metallica's Iron Man on loop while it happened. :P
PostPosted: Wed Jun 05, 2013 3:36 pm
Ouch!
BTDT myself. Those burrs work very well, but are not excatly cheap. I think the one I bought was over $40.
PostPosted: Wed Jun 05, 2013 3:44 pm
This $10 carbide bur worked well for me:
http://www.amazon.com/gp/product/B000VY ... UTF8&psc=1
'98 BMW M3
2013 Rallyx Co-VP
PostPosted: Sat Jun 08, 2013 12:25 pm
Glad the carbide burr worked out for you Michael. I should have also given you my tale of woe about using one; and that is to make sure to wear good eye protection and head covering. While porting a head I was careful to use goggles, but somehow a metal shard managed to fall out of my hair after I removed the goggles and I wound up in the ophthalmologist office while he pulled out the sliver with tweezers. Not fun.
Keep in mind it's not just the debris flying directly at you that can get to you, but the bits in your hair and clothes are often needle sharp (and pokey).
Charlie G
1998 BMW Z3
1987 BMW 325is
2000 BMW
1996 F250 Turbo Diesel
PostPosted: Tue Jun 25, 2013 4:57 pm
I keep a rare earth magnet in the garage to deal with the metal bits that fall out of hair and clothing and into one's eyes.
2000 Xterra SE
PostPosted: Tue Jun 25, 2013 6:39 pm
So, Brett, is the magnet in the shape of a comb or goggles or do you just hold it really close to your eyes and pull stray particles out of your eye? Inquiring minds want to know the details. I have a few rare earth magnets, as well as an assortment of speaker and fixturing magnets, but none seem like they could pick up a particle from one's eye from a "comfortable distance".
Charlie G
1998 BMW Z3
1987 BMW 325is
2000 BMW
PostPosted: Wed Jun 26, 2013 9:38 am
It is out of a hard drive, so it is kind of shaped like a semi-flat kidney bean.
It will tug loose particles out of your eye in a pinch, but it does have to be kind of close. I take it with me to the junkyard when I go.
It is purely an emergency item; if it doesn't take a bit of metal grime out of my eye, it'll be a trip to the Dr. Usually this and a good flush with water take care of whatever has gotten in there, though.
2000 Xterra SE
