 Post subject: importance of oil weight
PostPosted: Mon Mar 11, 2013 11:28 am
so, when dealing with fully synthetic, I know the first number does not matter. but what of the 2nd? I am thinking of running that rotella stuff in some of my vehicle, but am slightly deterred by some of them not specifying a 40w oil.
 Post subject: Re: importance of oil wait
PostPosted: Mon Mar 11, 2013 11:33 am
I just tried google translate from Mandarin and it's not that much more understandable. Checkout the oil thread or peruse BITOG.
Second number in a multigrade oil is the kinematic viscosity of the oil at 100degC. Most engines can operate quite well over a pretty broad range of operating temp viscosities and MFGs spec the lightest oil they can so that fuel economy numbers are 1-2% better for their EPA sticker numbers.
Which cars, the miata?
PostPosted: Mon Mar 11, 2013 11:40 am
JamesShort wrote:
The answer is German Castrol
Fixored.
PostPosted: Mon Mar 11, 2013 11:47 am
lesabre and the silverado for now. I know the lesabre requires 30w and I believe the truck does as well. so going with a 40w should be perfectly fine then?
PostPosted: Mon Mar 11, 2013 11:51 am
Fixored.
Or M1 0w40 (it pains me to suggest M1, but ONLY that weight).
PostPosted: Mon Mar 11, 2013 1:15 pm
I defer to James regarding oil info (I may post later to get recommendations on what to use for the Fit), but I am going to be pedantic about one thing. It is a button for me. And that is the term "weight" to describe oil. As far as I can tell, it is not a valid term for oil. The "W" (such as in 0W-30) is not "Weight", but "Winter". It is to indicated the cold temperature viscosity. So "0" when cold, "30" when hot.
Richard
PostPosted: Mon Mar 11, 2013 1:49 pm
Richard
Yes, 0W, 5W, 10W, 20, 30, 40 are all 'weights'. The W does not stand for weight as both the 'XW' and 'Y' in a XWY are weights (kinematic viscosity **ranges** at 40degC and 100dedC respectively).
PostPosted: Mon Mar 11, 2013 2:04 pm
Richard
I think we are mostly saying the same thing. My opinion is that the term "weight" has taken on a life of it's own, when in fact (as you say) it is really viscosity (kinematic viscosity). See if you can find any documentation anywhere that defines "oil weight" other than loosely using "Weight" and "Viscosity" interchangeably. I think "grade" or "viscosity grade" is more accurate than "weight". Anyhow, my main beef is that I think a lot of people think that the "W" in "0W-30" or "30W" means "Weight" when it doesn't.
Richard
PostPosted: Mon Mar 11, 2013 2:12 pm
All layman's terminology for describing motor oil in general are terrible. Lots of them are ranges that are loosely defined. Lots of misinformation about almost everything so I agree that the weight thing is one of these (of many).
The L15 is proving to be quite a robust beast (d series style). I'd bet you could run Walmart Supertech 5w20 conventional for 500k+ miles without issues.
That being said, I'm also an Amsoil fan. But for a non performance engine that isn't known for burning oil or being 'hard' on oil, I'd probably say an off the shelf Group 3+ synthetic would be more than appropriate for 10k oil change intervals. Every 0w20 oil is already at least Group 3/3+ synthetic. I've been running the Accords K24 (specs 5w20) on Penzoil Platinum 5w20 (always get in on sale for less than $30 for 5+ qts) for 10k OCIs since it had 0 miles. It doesn't burn anything and isn't noisy and the cam lobes are mirror like in finish.
PostPosted: Mon Mar 11, 2013 2:19 pm
Thanks for the tips regarding the Honda Fit (L series engine). I have read up on it, and it seem like Honda wants the best qualities of the D series when they designed the L series, but in a smaller, more efficient package. Knock on wood it will prove to be as good to me as my two D series engines have.
Richard
PostPosted: Mon Mar 11, 2013 2:21 pm
Richard
I should qualify that I meant 500k+ miles with reasonable OCIs 7500-10k miles :)....not 500k miles straight ;).
PostPosted: Mon Mar 11, 2013 2:31 pm
Richard
Crap, you mean I gotta change it! ;)
I haven't read deeply enough, but there seems to be lots of talk as to oil change interval on the Fit. It has an oil life indicator (that I think it purely mileage based). And I think it probably assumes synthetic with extended service intervals.
Richard
PostPosted: Mon Mar 11, 2013 2:43 pm
Richard
If you follow the MM, you will likely be heading towards 15k mile OCIs. My Accord's MM probably would get me to 12-13k miles if I waiting till it was at <15%. I do 10k OCIs so I can remember easy and the MM is usually at 35-40%.
 Post subject: Re: importance of oil weight
PostPosted: Mon Mar 11, 2013 5:46 pm
Official Mustang Tire Corder
Our 2007 Fit is the first car I've had that I said I would just follow what the maintenance minder said and go by the book. The light has come on pretty consistently between 5750 and 6000 miles every time. It's about to roll over 100k miles at just under 6 years. I've used Castrol GTX 5W-20 and had zero issues with the car. I wouldn't try to over complicate things.
Stephen Westerfield
PostPosted: Tue Mar 12, 2013 12:36 am
Best qualities ?!?! As in the D series propensity to spin rod bearings and blow head gaskets? No thanks!
Haha, those were from our days before we figured out the secret formula about how to bolt together (endurance racing) reliable honda engines :) Sorry for the digression :)
Mike (B series snob at the moment)
