Interesting idea on the propane tank. I skimmed the "how to". I think it I was to do this myself, I would either..
(1) Build the base with a slight incline to ensure it drains out of the drain bung that has to be welded in. but I am not crazy about his drain design. (Edit: Looking at his photos a second time and I see he has put block of wood under the back side in what is likely an attempt to help it drain toward the drain bung).
(2) Flip the tank upside down and plumb in a decent sized water trap (to avoid having to weld bung on the tank for drain). This would require more fabrication.
If I was doing a completely custom setup, I would also consider mounting the compressor separate from the tank (outside the garage, or in a soundproofed box, but with plenty of ventilation) along with some type of aftercooler setup.
Richard
