 Post subject: R compounds vs Street tires in the cold
PostPosted: Tue Feb 12, 2013 5:25 pm
So, if the temps are really in the mid 30's to low 40's on sunday as some pessimistic weather prognosticators estimate, is there really any value to me putting the r compounds on the car? At what temperature do street tires actually become the better choice. For purposes of my dilema, I'm comparing an ultra high performance summer only tire (Continental ExtremeContact DW) to Hoosier A6's.
 Post subject: Re: R compounds vs Street tires in the cold
PostPosted: Tue Feb 12, 2013 6:16 pm
Check out the 2nd post down from Per. Hope it's not true though because I'd rather not run on my 7 year old BFG street tires.
Lower pressures kind of makes sense I guess as you might get more heat in the outer shoulders from the deflection. Then again, I'm not an engineer and can barely install a set of Bilsteins correctly. :lol:
Cue Dr. James (Sheldon) Short.
PostPosted: Tue Feb 12, 2013 7:43 pm
According to Hoosier it appears you should not expose the A6's to freezing temps:
http://www.hoosiertire.com/rrtire.htm
"FREEZE WARNING
Freeze Crack Advisory: This advisory addresses proper storage and use of Hoosier tires in cold conditions. Hoosier Tires, especially asphalt and hard compound tires, may experience Rubber Cracking if the tires are transported, crushed, flexed or stressed when frozen. The following guidelines are provided to avoid this problem.
1. Always store Hoosier Racing Tires indoors at temperatures above 32° F.
2. If tires have been subject to 32° F or less, allow them to warm to room temperature (about 70° F)
for a minimum of 24 hrs before tire is mounted, transported or flexed.
3. Always use spare tires not intended for future competition to store vehicles for prolonged periods
of time or winter transport.
4. If below freezing temperatures are expected, please consider shipping tires once more favorable conditions exist.
Do not use tires that have evidence of Freeze Crack Damage."
Also, Woody from TireRack posted this in a RoadRaceAutox thread last month.
"As for the tipping point, and what tire actually works better, it all depends. Surface, conditions, and most importantly Tire A versus Tire B. There are some information sources that make a blanket statement of below 45 degrees you should take off summer tires and install winter tires (skipping A/S tires altogether). I'm not so sure that's always the case. Especially if you can get any temperature into your tires. Even if the tread warms to just 50-60 degrees while driving.
Max Performance summer tires like Conti DW are very good in the wet, and the Conti is particularly good under braking (a primary design criteria for all Conti tires, BTW). The grip/slip characteristics of summer tires get more sketchy and variable as the temperature gets into the low 40s or lower, which quickly shakes the confidence of the driver. But if you take an objective measurement you will find the grip of most summer tires is still better than an all-season or winter tire. It may be harder to drive but I'd bet lap time would be faster.
I did an anecdotal braking test some years ago with summer, all-season and winter tires (all now discontinued) on the Tire Rack test track, with ambient temps at 29 degrees and a light dusting of snow on the surface. I prepped the braking area by driving back and forth on it with another set of tires to create a 2-track lane where you could see the texture of the pavement in the driving line. Even in these conditions the summer tire actually stopped shorter than the winter or all-season tires. The ABS action felt herky-jerky as the summer tires gripped and slipped, but the car always stopped considerably shorter with the summer tires.
The best advice is to consider the most extreme conditions you'll have to race in, and plan for that. Let's face it, most of us don't autocross much at 34 degrees and raining. And if we do it's a local for fun rather than racing for a jacket in Lincoln. But if your conditions warrant a dedicated tire for cold + wet conditions, I'd suggest a good summer like the Conti DW, or one of the others such as Michelin PSS or Bridgestone S-04. Unless you plan on having to trudge through snow, avoid all-season tires."
According to "me" :lol:
Danville surface has a lot of "texture" which may create grip with a relatively heavy car.
For example the oem all seasons on my Mustang produced .9 to 1. g cornering at the Evo school in November.
Braking around .8 g and forward acceleration over .5 g (starting in second gear with the automatic and T/C off).
I'm sure those numbers are significantly better than the tires would permit on a smoother surface or a lighter car.
After the event the tires also gained "texture".
Personally, it is going to be far too cold for my slicks or my driver and even more importantly for my crew!!!
PostPosted: Tue Feb 12, 2013 9:49 pm
:sadbanana:
PostPosted: Wed Feb 13, 2013 12:41 am
Dick's posting reinforced my decision to just go slip & slide on my venerable and well-worn OEM spec M&S Pirellis. I was figuring that 75% used and slightly "crispy" A6s weren't going to behave well at 35 degrees, but I didn't know they would die.
Or.... what was that H-Stock PAX again? .804? What is the adjustment factor for Low-Rolling-Resistance tires? Maybe my Fusion has a future beyond commuting and road trips!
PostPosted: Wed Feb 13, 2013 10:47 am
Sounds like I'll bring them along to account for when the weather suddenly turns, but likely not bother mounting them up.
On a side note, now I know how I can beat Matt this season, and its the same approach I had to take my two FTP's last year. Hope for a season full of cold rainy autocrosses! :lol:
PostPosted: Wed Feb 13, 2013 12:38 pm
I'm really starting to regret removing the heater core from the Mazda. :roll: :stick:
09 Bullitt - DD
11 Fusion - Wife's DD
03 Mazda6 - Track car
00 PSD Excursion - Tow rig
61 F100 - Dad's truck
00 Cagiva - Adventure bike
00 DRZ400 - Woods bike
PostPosted: Wed Feb 13, 2013 1:37 pm
Online
Well on the bright side the weather channel is at least saying there is a low chance of rain for Saturday and Sunday. Which is a big improvement over the snow they had forecast a few days ago...... Of course there is still plenty of time for that to change :stick:
PostPosted: Wed Feb 13, 2013 2:36 pm
Pretty much covered already, but I'd be really careful using any R-comp in cold temps as it is possible to permanently damage the rubber. Various manufacturers warn about such, and the last set of NT-01s I bought in the fall had big yellow warning sticky labels on them warning about cold temperature damage. Falling below ~40F approaches the glass transition temperature of the rubber compound, and it begins to phase change. Think Space Shuttle Challenger o-rings. :(
PostPosted: Wed Feb 13, 2013 3:28 pm
DON'T JINX IT! :stick:
PostPosted: Wed Feb 13, 2013 4:49 pm
The heater in the bullet works doesn't it? Just saying...
PostPosted: Wed Feb 13, 2013 5:00 pm
As a Mustang guy you should know it's spelled B-U-L-L-I-T-T. :P
PostPosted: Wed Feb 13, 2013 6:09 pm
Im keeping my fingers crossed for 40+ temps then. For me it's either NT-01's or my pick up truck.
PostPosted: Wed Feb 13, 2013 9:14 pm
Yeah, but I'm dyin to try out the new LSD in the Mazda. :thumbsup:
09 Bullitt - DD
