 Post subject: Subaru WRX sway bar question
PostPosted: Tue Oct 23, 2012 11:37 am
Coworker has a newer WRX (2011), and he's looking to buy a rear sway for it. There's some AUS site that wants 125 bucks to ship a steel bar across the westward pond.
What do people with WRXs/STis like in their sway bars? Should get get a front instead?
He'll be running NOV DS next year.
 Post subject: Re: Subaru WRX sway bar question
PostPosted: Tue Oct 23, 2012 11:53 am
There will be a difference in choice based up on a WRX and STi, being the LSD's in a STi allow it to handle a bigger, beefier bar. Most of the guys I know who put a rear bar on a WRX ended up moving back to a FSB mainly due to lifting a rear tire off the ground mid corner. For a novice on street tires, I'd suggest a 25mm Perrin or the like up front.
I had a 34mm custom FSB on my STi, but that was with 295 A6's all around. - AB
PostPosted: Tue Oct 23, 2012 12:56 pm
Will the FSB also hold up well on the track?
PostPosted: Tue Oct 23, 2012 1:19 pm
Sure, no problem. I know the STi stock end links could easily handle a bar that small. I think the '11+ WRX has the same front end links. - AB
PostPosted: Sat Oct 27, 2012 7:44 pm
Did I miss something? Are aftermarket bars allowed in DS? Won't different bars move it to street prepared or one of the prepared street tire classes?
Charlie (out of the loop) G
1998 BMW Z3
1987 BMW 325is
2000 BMW
1996 F250 Turbo Diesel
PostPosted: Sat Oct 27, 2012 8:13 pm
Current rules are you can change EITHER the front or the rear bar in stock class.
