 Post subject: Loan out your welder?
PostPosted: Fri Oct 05, 2012 2:22 pm
Captain Caution !
Is anyone willing to loan us a portable welder for us to use on seam welding our new rally build? We've taken welding classes at TechShop so we're not complete newbs. Not sure if I want to spring for a quality welder for this fairly small task but don't think I should get a crappy cheap one either.
Advice welcomed.
Thanks.
Simon
< http://usukracing.com >
 Post subject: Re: Loan out your welder?
PostPosted: Fri Oct 05, 2012 2:30 pm
i have a small hf welder stashed in the garage, your more than welcome to borrow. I have not gas or anything for it.
PostPosted: Fri Oct 05, 2012 2:49 pm
Seam-welding with flux-core will be a challenge. You will have to stop after each pulse to remove the slag before restarting. I wouldn't recommened that.
PostPosted: Fri Oct 05, 2012 5:53 pm
^truth right here.
You don't have to spend $1000 to get a decent Mig welder that will do a good job. Definitely get one that is either ready to use gas, or has a reasonably priced "gas conversion" kit to enable you to use gas.
I did a bunch of welding using flux core wire, and it was OK to stick a couple of pieces of metal together, but the welds looked like ass, and I never felt I was getting a good clean weld. Once I switched to true MiG welding, it was a world of difference.
I haven't priced welders recently, but I would think you could find a good setup for ~$3-400 max, and believe me, you'll use the heck out of it building that race car. Do it.
PostPosted: Sat Oct 06, 2012 8:15 pm
http://raleigh.craigslist.org/tls/3278615139.html
PostPosted: Sat Oct 06, 2012 8:29 pm
I'd check to see if that Lincoln Pro 135 is capable of using gas, but if so that's a damn fine deal. If it's a flux-core only machine, keep looking.
I have a Lincoln Pro 140 and new it's about $550, but it comes ready to use with gas since it includes the regulator. I bought it used from Ryan, who bought it used from another guy. It's never missed a beat.
PostPosted: Sat Oct 06, 2012 9:12 pm
It does say MIG on it, the "G" stands for gas. It also says "set up for gas" in the ad.
For now, Simon is using a comparable Hobart for the cost of consumables.
PostPosted: Sun Oct 07, 2012 7:39 pm
I missed the "set up for gas" in the ad. :oops:
I know what the "G" stands for, I took two semesters at the local community college to learn how to weld. Lots of people advertise a flux-core-only machine as MIG. Most consider
"MIG" a generic term for a wire-feed type welder.
Hobart also makes a good unit. I advise you to buy a welder from one of the "big three". Miller, Lincoln, or Hobart.
PostPosted: Tue Oct 09, 2012 10:50 am
I took my dad's advice and bought a 240V Mig so I would have a built-in excuse for not loaning it out. "Oh, I'd love to, but its 240V. You don't have a 240V welder outlet? Bummer." :lol:
That said, I've had many folks stop by the garage with their "welding projects". So it's not a perfect solution. :D
Good luck!
09 Bullitt - DD
11 Fusion - Wife's DD
03 Mazda6 - Track car
00 PSD Excursion - Tow rig
61 F100 - Dad's truck
00 Cagiva - Adventure bike
00 DRZ400 - Woods bike
PostPosted: Tue Oct 09, 2012 10:53 am
Good luck!
The solution is to buy two welders.
A 240V model and a cheap Horrible Freight 120V model to loan out.
PostPosted: Wed Oct 10, 2012 1:33 am
Heh. Why, Yes I do. The compressor is plugged into it. And it's not remotely a legal plug. (of all the things the inspector bitched about, the 120 socket with 240 on it, not screwed down... that was ok.)
PostPosted: Thu Oct 11, 2012 4:42 pm
I have a lincoln HD140 (and 60CF of gas) - I live in the Hickory area. How long would you need it for? This is something I would like to do to my "rally" MR2 (<- want to build for real Rally, currently RallyCross) so I'd be down for a welding session or two ;)
EDIT: It's not a generator powered one, you'd need 120V.
