The wiring converter is the way to go on a Miata. Being directly powered by the battery at the rear of the car is safer for the car's electronics and makes the trailer lights much brighter too. My trailer lights are WAY brighter when hooked to the Miata vs. my Cavalier w/o a direct wire converter. My trailer has a
few more lights (see the pics) than most so it matters to me.
All the other trailer designs I've seen are much like Chuck's using straps, cables, or whatever to secure the wheels. My method while more elaborate, is IMO much easier to use. I unlock the pad lock, slide out the security rod and that's it. I took special care to design the rod the correct diameter to just barely pass through the center bore of the wheels to eliminate up and down travel. Take a look at these pics.....
http://www.bradiscool.com/solosportraci ... iler_1.jpg
http://www.bradiscool.com/solosportraci ... iler_2.JPG
http://www.bradiscool.com/solosportraci ... iler_3.JPG
The vibration problem that Chuck is talking about regarding the bulbs was solved using "grommet mount" lights in my toolbox. These are used on semi trailers which bounce quite a bit as well. The oval light is mounted inside a rubber grommet (friction fit) and allows it to absorb shock better. BTW, the ones in the pics are the old incandescent-type that I've replaced since with the new cool LED kind...more bling-factor! While I don't travel as much with mine as Chuck and Donna, I haven't replaced a bulb in over 5 years using these lights.
Some sort of support for the tongue (like my kickstand-type) will make your life easier. I bought mine direct from the manufacturer for $20 and it bolts right up to the factory holes.
Like I said before my setup is more elaborate, but not *that* expensive. Mine was expensive because I used aluminum diamond-plate (read: more bling-factor) but the same can be accomplished much cheaper. We built Ryan's trailer using basically the same design for half the price.
Like Diane said, it's pretty darn nice to just hook-up the trailer knowing all your stuff is packed and ready to go every time. In my case the benefits out weighed the costs 10 fold.
