Charlie Guthrie wrote:
Bret, check the voltage at idle. The clutch is electric and needa a minimum voltage to pull in. If the pressures were off, it wouldn't pull in even at fast idle since the pressure won't change until the clutch engages.
Charlie G
hmm, good point- and easy enough to check. Alternator is fairly new, so hopefully it's doing it's thing, and one of the batteries is brand new.
George- I did a quick look and didn't see a sight glass, but I'll look again.
Mike- thanks for the tip, I'll look into that manifold set if it looks like the system needs some freon.
Thanks for the help guys - I'll post up if I find anything new.
