 Post subject: Oil coolers - need some ideas!
PostPosted: Mon Jun 20, 2011 12:57 pm
We were experiencing crazy high oil temps on the chump/lemons integra at CMP this weekend -- hitting 300F+ during a hard session (in 98 degree heat). For a long race, we've got to do an oil cooler.
Anyone have suggestions for junkyard what cars out there might be a good donor? The bigger the better up to a point.
Any suggestions (or thoughts on why the heck we're seeing so much oil temp) would be great!
 Post subject: Re: Oil coolers - need some ideas!
PostPosted: Mon Jun 20, 2011 1:12 pm
I know that the GD chassis WRX have oil coolers and they have the same threading and gasket diameter of Hondas. And RSX-S and 8th generation Civic SIs have coolers too which will probably spin right on the d/b series.
PostPosted: Mon Jun 20, 2011 1:41 pm
Pseudo cautious/nervous guy
Volvo 740/760/940 turbos have pretty meaty oil coolers from the factory. They're a little old, but I'd think you could find one in a pick and pull.
Tom Freeman
Team Silver Bullets '91 240SX
PostPosted: Mon Jun 20, 2011 2:04 pm
Tom do you hav any idea on what year? I prob have something here for Mike then.
PostPosted: Mon Jun 20, 2011 2:15 pm
There should be a BIG range of years on those. I think the first 740 turbos came out in 85, and I think the 940 turbo was made until 92-93. That motor changed VERY little in that span of years.
Tom Freeman
PostPosted: Mon Jun 20, 2011 2:59 pm
On the unlikely chance that you don't know this already :lol: keep in mind that oil coolers are extremely difficult to get really clean after an engine failure and can easily cause another engine failure. :cry:
PostPosted: Mon Jun 20, 2011 7:18 pm
2nd Gen RX-7's have a nice oil cooler and are generally cheap to pick up used.
Its kinda weird you guys are having such high temps. We were worried about ours but have never seen anything close to 300* AFAIK
PostPosted: Mon Jun 20, 2011 7:26 pm
does yours have a oil-water cooler? many cars do, usually at the oil filter housing. the d16 integra had one but the b18 does not.
PostPosted: Mon Jun 20, 2011 7:38 pm
Yeah I think ours does but I always was told it more of an "oil heater" than cooler.
PostPosted: Mon Jun 20, 2011 7:45 pm
it's both, coolant heats up faster than oil in cold weather, and is lower temp than oil in most other conditions. provided your cooling system has enough capacity to handle additional energy it's a cheap, reliable, and easy way to reduce oil temp.
PostPosted: Mon Jun 20, 2011 9:24 pm
if you could make an auto trans cooler work i have two from e36's laying around that you can have for $00 if you want to try. they are not as thick as other coolers i have seen but it is roughly 1/3 the size of an e36 radiator.
#77 nasa spec 3
e36 M3
PostPosted: Mon Jun 20, 2011 10:10 pm
I'm leaving Friday to head up that way for the Danville autoX after a short stop to see my parents, would be glad Mike to bring them by your place on Sat on my way thru the area
PostPosted: Tue Jun 21, 2011 10:34 am
Sean, do you have any idea for what the ID of the pipes/fittings are for those? In the little I've been reading, the issue with using trans coolers is in the flow rate of generally smaller piping... especially since we're already seeing fairly high pressures and ALL oil is diverted through the cooler.
Single point of failure FTW! :?
PostPosted: Tue Jun 21, 2011 6:04 pm
They look like they are 10 to 13mm diameter, ill try to find some callers and get an exact measurement as well as some pics
#77 nasa spec 3
e36 M3
PostPosted: Wed Jun 22, 2011 12:47 pm
sorry mike i keep for getting to look under the house. None of my Volvo's have the coolers. What about a truck?? let me go look for some of those
