 Post subject: Longshot: Anybody have a fender roller I can borrow?
PostPosted: Thu Apr 14, 2011 12:32 am
Drive my car for the first time on 225s today and bent the front fenders from the tires. :oops:
If nobody has one, a mallet and 2x4 it is.
Thanks
 Post subject: Re: Longshot: Anybody have a fender roller I can borrow?
PostPosted: Thu Apr 14, 2011 8:03 am
I have a metal baseball bat and some 1/2 inch pipe :lol:
2005 Mazda 6 Wagon
PostPosted: Thu Apr 14, 2011 9:24 am
Thanks
You are rubbing in the front? How is the rear fender clearance?
Sounds like you need moar cambers.
PostPosted: Thu Apr 14, 2011 9:28 am
The rears are fine and are set at 12.5" hub to fender, the fronts are 12.25" hub to fender and it's tight.
So tight that... http://i.imgur.com/XIyVa.jpg
PostPosted: Thu Apr 14, 2011 12:30 pm
What size wheels are you using? I actually just ordered another set of 15 X 8 wheels for tires the same size and I didn't think I had to do a roll.
2005 Mazda 6 Wagon
PostPosted: Thu Apr 14, 2011 12:37 pm
Yes Rob you do need to roll them a bit. You and Andrew check this out. Pretty good video covers it.
Rolling Miata Fenders
PostPosted: Thu Apr 14, 2011 1:24 pm
You,my friend, have been Rick rolled. Graham, didn't know you had it in you. :lol:
PostPosted: Thu Apr 14, 2011 3:13 pm
I don't know what is going on with Andrew's car. I'm blaming weaksauce front camber. :)
I have 225/50s on 15x9s and I didn't rub in the front at Sanford. I had to roll the rears flat though. Our offset is about the same as well. I'm a touch lower but I'd think that would make it worse for me since I would get less extra camber when the tire is even with the fender given the same static camber.
PostPosted: Thu Apr 14, 2011 4:04 pm
I'm at -2 degrees in the front and it did that with 225/45R15s on 15x7s.
I'm punching them out tomorrow if I have the time.
The comedy option is to get flares.
PostPosted: Thu Apr 14, 2011 4:09 pm
dang i put my 275's on 15x9 and with out the car moving i can turn lock to lock with no rubbing issues. Going around the block tonight to see how much to cut out.
PostPosted: Thu Apr 14, 2011 5:14 pm
If your 15x9s are 6ULs watch out when going lock to lock, you're limited by the wheel hitting a control arm without spacers.
PostPosted: Thu Apr 14, 2011 5:26 pm
Just got back from work; no rubbing unless if I gun it through 90 degree turns. If I do gun it through 90 degree corners: lolololololol
