OK, I need some advice. I just picked up a ’99 Golf straight drive w/ 77k miles for $1200. Couldn’t pass up that deal. Had the 60k service done to replace the timing belt, drive belts, water pump and so on. Has basically new tires and alignment and drives great.
Right now I’m setting this up as a DD, but it has a few issues. One of note is the ignition switch. Right now it’s in 2 pieces and I need a screwdriver to start the car. I have a new switch assembly that I bought from Jeremey at Wagner's, but I need a recommendation for a lock smith to re-key the replacement tumblers. Any suggestions?
If Jeremy has the VIN for the car the new ignition switch came from you should be able to get a new key no problem. I had one cut for my Z-24 via the VIN a few years back.
