Aaron Buckley wrote:
Unless clutch disc has gotten so worn that it's really scored the flywheel, just a clean up of the surface is all I would do.
Just a data point for y'all - I just changed the clutch on the WRX. The clutch had been slipping for the PO for a long time and the surface was pretty blued. I decided to be cheap and lazy and didn't address it. Now there's a little bit of vibration during launch, not buttery smooth. I'm fine with it, doesn't bother me much.
Just to point out that worst-case (this was) is still OK for a tolerant driver. I agree with the other guys, don't bother.
Along similar lines, but maybe different outcome -
I've done clutches in a Miata, Subaru, and CRX. The CRX and Subaru flywheels were resurfaced at CarQuest, but the Miata was a new MazdaSpeed Motorsports replacement. Both the CRX and Subaru had a small amount of "vibration" or chatter at launch, and I was anal about proper installs, but the Miata was butter. For the same price, I would absolutely opt for a new flywheel. But as others have noted, I would probably think twice about doing anything more than a scuff unless there was significant scoring in the flywheel.
