Quick question:
For front- and allwheel-drive cars, should there also be a thrust angle for the front wheels?
Since those wheels steer, not really.
Say you use simple toe plates and get your front wheels to a total toe of 0 and yet relative to the chassis the driver wheel is 0.2 deg toe in and the passenger wheel is 0.2 deg toe out (again, this is zero total toe, but probably not what you were going for). You have a thrust angle per se, but those wheels turn so there will be a steering angle such that the thrust is zero such that the car goes straight ahead....however, you will no longer have 0 toe anymore.
So basically park the car with the steering wheel perfectly centered, pull the key, wiggle it to lock the steering and then do your alignment making sure to get your toe in, 0 toe or toe out relative to the chassis and even on each side (ie this method).
