KendtEklund wrote:
Maybe this should be a poll - but there's been enough of those lately
I'm helping a friend with her 97 Chevy truck - the brakes feel *terrible* to me - spongy, overboosted, and you can push the pedal right down to the floor after stopping with enough effort.
Some googling leads me to plenty of threads about 'that's just the way these Chevy brakes are' - even an article from a parts supplier to service reps about how to deal mainly with the customers, not the brakes!
I'm going to probably have a go at a full system flush, and see if I can get the device needed to actuate the abs during bleeding.
How many Chevy truck owners here have this problem, have solved it, or are just living with it?
My 01's brakes are likely similar, and I too have done the Interweb searching. Chevy has gotten a lot of comments on this, and they addressed it (supposedly) with the latest body style by increase stiffness of the firewall and MC/booster and going back to rear drums (maybe that was just cost savings, too).
They have a lot of pedal travel before they start to hook up, but after an inch or two they start to grab decently. Now, if your pedal is truly going to the floor, then you may have an issue - but an inch or two of pedal travel before anything good happens is pretty normal. If you reference is your Ford truck, then I see the issue - Fords have a COMPLETELY different brake feel that is much more reassuring.
FWIW, my concerns for my truck's brakes went away when I got my M3 and realized those are just as bad. You get used to it.
Note that corrosion on the rear calipers is common on these as well since the rear calipers are more exposed than in cars (due to lack of rear wheel wells). These trucks are are also heavily rear brake biased (as in I have 120k miles on my ORIGINAL OEM front pads, though the rears were changed at ~80k). Put these 2 issues together, and you have a system biased toward the end that doesn't want to work right. Consider at least a careful inspection of all the moving parts in the caliper and whether a rebuild/replacement might be in order.
