MarcusMcRae wrote:
Jason Tower wrote:
MarcusMcRae wrote:
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&N=0&Ntk=All&Ntt=36mm+socket&Nty=1&D=36mm+socket&Ntx=mode+matchallpartial&Dx=mode+matchallpartial
I did not get the pimpy impact version. I got it at the store in cary. Call before you go to check availability. I still have it if you want to borrow it.
Edit: What's the price on the e30 front wheel bearing? The E36 bearings are still close to $100. I had to replace the right front for the second time just before I sold it. If RRT is still selling their lifetime wheel bearings I recommend you look in to them.
never heard of a rrt lifetime bearing. i got a replacement from turner, cost about $130 including the nut and dust cap. plus i got new studs so i wouldn't have to deal with removing the old ones on short notice. i'll yank them later and keep for spares.
Remove the studs befor you pull the hub. It's a thousand times easier. What kind of studs are in the hub now?
RRT used to sell a bearing that they custom built and said it would last forever. Go ahead and buy a socket from NT. You'll need it next year
i'll call NT and see if they have one on hand. if the OD is too large i'll have to grind it down so a rental tool might not work anyway. might as well buy one, it's not like this is the last time i'll ever use it
i don't have a torch to heat it up and break the locktite so pulling the studs now isn't an option. no idea what kind they are (already installed when i bought it) but they look just like the ones that BW and turner sell, 75mm long.
