JamesShort wrote:
Aaron, could you enlighten me as to the need for a FSB that big? 32/34mm?
I understand with the front strut suspension, you want to stay in negative/neutral camber for both lateral grip purposes as well as to keep from eating up the outside shoulder on your expensive and very wide r comps. But isn't there a point at which your effective wheel rate in roll conditions is so high that there is no more benefit of going any larger...in fact wouldn't it eventually be come a detriment to go stiffer given that you'll be lifting inside front tires to a greater degree (as in per unit turn, that tire will be off the ground for a longer amount of time)? And this will in turn transfer even more weight to the rear at corner exit (than it would purely from starting to accelerate hard again) and cause the car to push?
Just something that I've been wondering.
When it comes to setup, I'm not very technical and will never claim to be.
For autocross, there are very few "long" sweepers. It's all about quick transitions. The previous versions of the STi suffered from lacking the ability to quickly transition due to a soft front spring and a heavy car that was somewhat under-tired, even with 275's on the GD chassis. With stock class, only being able to change the FSB, you move to the biggest bar the car can handle and adjust toe to get it to rotate.
I spoke with Chris Carris for about 1.5 hours the week after I ordered the car. He was running a 32mm bar (as was anyone serious about running an STi) and said that it could have used a 34mm bar. If he hadn't ditched it, he would have had Niles build him the 34.
I also PM'd a bit with Jonathan Roberts, who piloted Donnie's '05 STi to 3 ProSolo championships. Jonathan said the car was best when the front bar was binding up, just prior to ripping the tab off the control arm
Obviously, roll stiffness has a point of diminishing returns. I have both a 32mm and 34mm bar and could change it out in about 10 minutes. With the SE's spring rates upped 16% in the front and 29% in the rear, my guess is the car could be fine with the 32mm bar, but I'm going to start with the 34mm. If I have to toe it out to make it rotate properly, that's fine, for what I gain transitionally from it will be worth it.
In your car, if I were to put R compounds onto it, I would be running at least a 30mm FSB. While the front end roll on streets wasn't horrible with your 25mm, it was noticable.
My view on FSB sizes changed a lot when driving the Corvette. We had 3 FSB's for the car: 32mm solid, 35mm hollow and 35mm solid. Of all of the bars, I liked the feel of the 32mm solid the best, but the clock said that the 35mm hollow was fastest.
There's a guy named Matthew Braun who has won a bazillion Tours/Pros/National Championships. He's a serious alien. The way he setups his cars (he tends to only drive RWD cars) is to put the biggest bar on a car that will make the car *slightly* push in transition and then steer with the throttle to make it rotate. There is a reason he is fast. - AB
