 Post subject: you don't really need all the bolts on the oil pan, do you?
PostPosted: Thu Jan 28, 2010 4:14 pm
Michael and I have almost finished replacing the oil pan on his 93 Subaru Legacy. I over-torqued one bolt and broke it (due to a misreading of the torque specs). It's one of the nearly-impossible-to-get-to ones in the back, so the outlook is bleak. So....
1. How do I even set my torque wrench for 4.2 INCH pounds? Isn't hand-tight good enough?
2. I don't really need that bolt, do I? I have about 11 more...
Thanks!
Maria
PostPosted: Thu Jan 28, 2010 4:27 pm
The spec on those bolts are around 4 foot lbs. (3.7 for the new WRXs...similar I'm sure for the older Legacy). Where did you read 4.2 in pounds?
What I would do is torque the rest of them properly and fill her up with oil and let it run for a bit to see if it leaks. If not, then just be vigilant about checking up on it.
Did you use some high temp rtv on the gasket?
PostPosted: Thu Jan 28, 2010 4:52 pm
What I would do is torque the rest of them properly and fill her up with oil and let it run for a bit to see if it leaks. If not, then just be vigilant about check up on it.
I meant 42 inch pounds. Yes, high temp goo on the gasket. Thanks for the advice.
PostPosted: Thu Jan 28, 2010 4:55 pm
ok, that is equivalent to 3.5 ft lbs. Unless you have a in lb torque wrench, your's probably doesn't go that low. I have a 20-220 in lb you can borrow if you want.
PostPosted: Thu Jan 28, 2010 4:57 pm
make sure that goo sits for a white before you start the car up.
'11 RallyX VP
1999 Subaru 2.5RS - dirt fun
PostPosted: Thu Jan 28, 2010 5:07 pm
Good point, RTV needs to cure cold for a while before starting it up...sorry.
PostPosted: Thu Jan 28, 2010 5:17 pm
Ask Ryan Holton. He leave bolts out all the time. He will probably say,"It really isn't all that bad."
Rubbin' is Racin'
PostPosted: Thu Jan 28, 2010 10:23 pm
How long did that CRX engine last? :)
PostPosted: Thu Jan 28, 2010 10:32 pm
That would be great - thanks. Maybe I could pick it up tomorrow?
PostPosted: Fri Jan 29, 2010 12:38 am
Sleeper
I hope you used the fancy Subaru gray RTV - it's really extra good RTV, nothing like what you get at AutoZone.
(I didn't torque these when rebuilding my RS motor - just snug with my hand over the end of the wrench. The RTV just needs an even smooth pressure to bond well.)
--Kevin H.
2003 WRX (again!)
PostPosted: Fri Jan 29, 2010 12:41 am
Harbor Freight carries these too.... cheap.
PostPosted: Fri Jan 29, 2010 8:44 am
There are products called something like "spreaders" which are used on old style metal valve covers that are used to "spread" the clamping force from one bolt to the area roughly halfway to the next bolt. Should be able to find them in a typical parts store. They are shaped to act more like a spring than just a flat piece of steel. Also, I've seen some pans where there is an "extra" piece of steel that bridges several pan bolts. If there is room something shaped more like an angle iron would reist bending better than just flat steel.
PostPosted: Fri Jan 29, 2010 10:49 am
This little project is a testament to the fact a lot of cheap adds up to expensive :)
PostPosted: Fri Jan 29, 2010 11:00 am
But no excuse is to small to justify a tool purchase!
PostPosted: Fri Jan 29, 2010 12:34 pm
--Kevin H.
No leaks anywhere as long as I owned it, either.
