Speaking from experience (but not Subaru experience) sometimes the engine has to be lifted to work the oilpan free from between the block and front crossmember, not just for bolt access. I think a hoist would be better than a jack, especially given the oil pump issues James mentions. I had to replace the oilpan gasket in the Z, and loosening the engine mount bolts and raising the engine even just 1/2" made the job very easy.
I should have qualified that you shouldn't jack it up on the oil pan......there are open areas of the engine block that you can jack on or you can jack the tranny up (there is a nice flat area to jack on). So to itemize:
-Remove pitch stop/dogbone mount
-Loosen the two engine mount nuts (don't remove all the way)
-Jack the engine/tranny up a bit (2 inches or less) (if doing the engine, don't jack on the pan, use a 4x4 vertically so that the end is pushing directly on the engine block
-Now for safety, we need to secure this with more than the jack so you can:
*Put 2 long sockets between the subframe and block near the mounts and relieve the jack so it is stuck in this position
*Put chunks of wood in the same place as above
*Use jack stands with some wood to hold the transmission or front of engine up.
-remove all the obvious oil pan bolts (10mm)
-using a 1/4" drive extension and a ujoint go in through the subframe holes at a slight angle to get the back 4 bolts
-remove the dipstick tube bolts and pull it out of the pan
-drop the pan
Check the pickup up near where it mates to the block to make sure there is no crack.
When you put it back on use some gasket sealant and torque the bolts to
3.7 ftlbs (criss cross, little at a time fashion). For the back bolts that you use the u joint in, set your torque wrench to about 4.1-4.2 ftlb to account for the drive angle.
Reconnect the dipstick tube.
Some people on the forums have noted that the OEM motor mounts have enough flex that you can jack up enough to get the rear bolts without loosening the motor mount nuts (those are 62.7 ftlbs)
