Mark Vitacco wrote:
I currently set my diagnal weights at Krause & England.
The going THSCC rental rate is $75.00...
...In the mean time I keep paying Peter to use his scales.
Ok, here are some follow up questions.
With respect to using Krause & England's scales...
* In practice how does this work? Do you make appointment and do work at their shop? Take scales home for X hours?
* If you do the work at their shop do they have someone to read the scales while you sit in the car or do you need to bring your own helper?
And in general...
* How long does it take you per session to get your corner weights were you need them?
* I assume this is done via adjustments to spring perches on each corner. Does the adjustments cause geometery changes that you need to realign the suspension afterwards? In my case with Honda double A arms all around and with me not having aftermarket adjustable length arms or shims, I am assuming that I can play with corner weights via Ground Control perch adjustments and there is nothing that I can do with respects to the resulting suspension issues (in this case most likely slight camber changes) that results?
As you can tell I am a total newbie on how to go about doing this.
