AndersGreen wrote:
All well and good.
Now, what about the subsequent runs? And was it determined that this actually is low? (It seems that it is.) Was anything tuned? What were the exhaust gas readings?
Anders, looking for "the rest of the story"
Hey Anders - I'm looking for the rest of the story too! OK, here goes. I'd appreciate any input anyone has.
The car - Factory rated at 90 HP, so we'd expect 70 or so if all is well. So we're missing 20-25 HP. Idles, revs, and runs well, good midrange torque. Totally loses breath as the revs rise - the torque curve peaked around 2500 RPM and fell nearly linearly all the way to redline. Very unusual even for a carbed engine. HP curve is almost flat - not what you want.
1. Initial run around 48. A:F looked fine (need to look up what it was)
2. Changed timing to "full opposite" = 42 hp (determined retarded)
3. Put timing back to full advance. Did another run while watching secondary throttle. Throttle wasn't opening. About 50 HP this time (higher b/c missing air filter).
4. Leaned over the engine and shoved a screwdriver into the secondary during the run. Went to like 52? HP Noticeable improvement across the board. A:F went wayyyy rich.
5. Repeated #4 with compressed air shot into the carb secondary. HP bumped up to 54 (?) and A:F was OK.
So the secondary problem appears to be part of the issue, but at this point it looks like it may only be 10 of the missing 30 hp.
It really runs like there is some massive breathing restriction, right? Works fine at low RPM and not at high. What could this be?
