Keith Vail wrote:
I believe 25 gallon is the maximum size fuel cell you can use, at least it is for IT. Many teams use Nascar style dry break dump cans. I know a team that we ran next to last year could fill their 25 gallon cell with 2 dump cans in under 1 minute. Even if you are done fueling, with the driver back in the car and set to go you must be in your pit box for 2 minutes every time you fuel the car.
Uh, you sure about those numbers? You mean they had 12.5 gallon dump cans and two dudes big enough to haul them around and got it done in under a minute? It almost had to be a smaller cell and less in each can for it to happen in under a minute.
We have a Grand Am fuel rig. It's a big tank mounted with the top at 6' high on a big stand. It has a 2" hose (I think...either way it goes to the same size dry break that the NASCAR dump can would use and the hose is at least that big) coming off of it and goes straight into a dry break in the back of the car. It takes us about 50 seconds to fill 25 gallons. It can be improved with a two hose system so that the vent is bigger, but I'm skeptical as to how much. But a dump can system should have the same vent on their cell that we have now, which makes it hard to go any faster. Plus those dump cans won't have the gravity advantage that our tank will.
But we're quibbling over a few seconds here. And it's not JUST about fast driver changes. It's about being able to get out safely and quickly. I prefer something with a bigger door for that. *shrug* Yeah, I still drive my SM and probably will for a while, but I don't like that part. Not one bit. So I don't want to do it all over, particularly if it's going to be annoying for the driver changes.
But yeah, 25 gallons is the max under the rules. You're also only allowed to have 25 gallons of fuel in the pits at any one time, too. So every time you fuel the car you have to use something to go OUT of the pits to another fuel source and bring fuel INTO the pits to refill whatever fueling rig you use.
Note that many classes don't allow a dry break, though, such as Spec Miata. With those you still have to use a funnel.
As for fuel mileage, I'm just quoting numbers I've found people have posted from their cars. I can't imagine short shifting a little getting you 2-3 more MPG when we're talking numbers this low already. As for a 911, well, I'm just not that interested in paying for a Porsche. If I were, I'd build a Cayman instead. Better balance but the same as a 911 otherwise. No way I'm doing a Lotus anything. I barely fit a stock Elise with no cage. There's no way with get the big fella in one without a shoe-horn and some butter.
