Chuck Branscomb wrote:
Just remember that Brian's car has the Euro 3.0 motor in it, which isn't exactly common in the US. IMO for an endurance car I think you'd be better off sticking with an S52 simply because there will be plenty of people who know them, spares, parts from bimmerworld overnight, etc.
I'd follow that thought up with some investigation as Bimmerworld stocks lots of parts for these Euro motors I believe. They have done a number of conversions by importing them. I think it is a Euro 3.2L btw which is essentially almost equal in output to the E46 M3. It has multiple throttle bodies but unlike the E46, it uses a mechanical connection (throttle cable).
I'm curious which would be more reliable: an S52 modified with many non-factory stuff to reach 275whp or a factory motor with such power. I truly don't have an answer other than my gut answer from modifying cars in my past (and the gut is screaming factory).
Rough numbers from memory:
US 3.0 = S50B30US = 240c(rank)hp, <240tq; tens of thousands in the US
US 3.2 = S52 = 240chp, 240tq; tens of thousands in the US
Euro 3.0 = S50B30 = 286chp; import-only, rare compared to production motors
Euro 3.2 = S50B32 = 321chp; import-only, rare compared to production motors
280chp S52 is made by swapping intake manifold (M50), exhaust, and custom software. I dunno if it's any more or less reliable than a euro motor but it certainly is more common. Destroy the head? Call one of a dozen shops within 2 hours of VIR for a replacement.
Read the description of the base Euro motor and you can start seeing why this would be a bad (IMO) idea for an endurance motor if you expect short downtime for any engine related repairs:
http://en.wikipedia.org/wiki/BMW_M50 wrote:
The S50B30 was a special sports-oriented 3.0 L version, which powered the RoW spec E36 M3. Power is 286 hp (210 kW). The S50B30 has a bore of 86 mm and a stroke of 85.8 mm, with a total displacement of 2990 cc. The engine has a maximum permissible speed of 7280 rpm +/-80, and a permissible constant speed of 7000 rpm. It used an ITB intake system with an oversized MAF and a tubular exhaust manifold. The cylinder head was unique and the VANOS system was more advanced than the one used on normal M50s.
