Karl Shultz wrote:
I'm having a bit of a hard time interpreting the document. Would anyone mind doing sort of a "Cliff's Notes" version?
BTW - when I owned Kevin's Excursion, which is a 2WD, I drove it across the scales at the Durham county dump, and indeed, it weighs about 7500lb. or so. 76xx something, actually - I wish I'd kept the printout. I knew it was heavy, but...damn.
Anyway, when I had it, I ran a weighted tag. Some people, on this forum in particular, told me that I was doing so unnecessarily. I chalked it up to "better safe than sorry." I was towing an open trailer with a tire rack and a Honda Challenge Integra GS-R. Probably about 4500lb for the trailer.
Small wonder I called the Excursion "Gigantor."
I didn't read the document, but IIRC, a regular passenger car tag is only legal on a vehicle up to a certain max weight- somewhere around 6-7k I think. This is GVW or Gross Vehicle Weight, which means the vehicle fully loaded with whatever you load it with, including trailer (if applicable) and cargo.
There was a big to-do about this a couple of years ago, folks with full size 1/2 ton pickups (F150, etc) and SUV's (Expeditions, Excursions, Suburbans, etc) were getting nailed for having passenger car tags, when most of these vehicles were over the weight limit even before you add any passengers or cargo. Those folks were (and are) supposed to get "weighted" tags. With these tags YOU can declare the max weight you want, but it's a good idea to know what your fully loaded rig can weigh, and maybe add a little cushion in there just in case.
For example, I have a 96 F350 crew cab diesel dually pickup with a solid deck 18' steel car trailer. I originally put 11k on my registration, but upped it to 14k when I realized that I was probably overweight with a heavy-ish car on the trailer and a bunch of crap in the bed of the truck.
I think if the DMV or SHP guy gave you a ticket for being overweight while driving a "regular" SUV around town they are just being a-holes. But if you get pulled with a car on or in a trailer and you look like you've done it before- you are fair game. I think as long as you are trying to comply with the law you should be OK. If you get a ticket for being overweight, chances are you can get it dismissed by showing up for court with the documentation proving that you fixed the registration to cover the additional weight.
If you're driving a
commercial vehicle, they can and will write you up for anything and everything. It's getting kind of ridiculous, but I've seen some really crappy rigs out there so I hope they get them off the road.
