Keith Quistorff wrote:
After seeing how "low def" SPEED HD actually appears on my HDTV via Time Warner Cable, I'm reconsidering paying a little more for DISH Network. A few questions for those with DISH network:
1. Do the DISH remotes include programmability / functionality for other components besides the DISH receiver, like TV amp, DVD player, VCR? If so, how many components?
It has one AUX input button that you can use to program another component. Honestly, if you want to control more than just volume on your AV receiver (for example) I'd recommend getting a smart remote to control everything (including the Dish unit.)
2. How does the second TV get connected to the dual receiver/DVR? Do you have to run a cable from the receiver box to the second TV? If so, is that included for free with DISH's (free) standard installation service?
Yes, you have to run a coax cable to the other TV... and yes, it is included... I think. Obviously, the difficulty of this installation depends on your house set up... if you have a crawl space, or if the rooms & TV's are back-to-back, it's fairly straight forward. If not, it gets a little more complicated (we lived with a coax cable snaked across a hall until we did out re-model (and I had them run dual cable for every TV.)
3. When hooked up for 2 TV operation (dual mode), can you record more than one show at the same time from the primary TV? I've read you can record one show on the satellite tuner and one on the OTA tuner at the same time, but what does that mean in layman's terms? (like, would you need a second receiver or antenna to utilize the OTA tuner; is the channel line-up any different on the OTA vs. satellite tuners?)
It works like this:
The receive has two modes... Dual or Single.
In Dual mode, the main TV and the TV hooked up to the "TV 2" output are operated separately. Each using one of the two built-in dish tuners, each with its own remote (included). So... on EACH tv, you can record one program and watch another. You can still record two programs at the same time, but one has to be started on each TV. In fact, you can record two programs, and WATCH two recorded programs at the same time. When setting up a future recording, the Dish unit will appropriate whichever tuner is not already recording something at that time.
In Single mode, the Dish unit works just like any other two-tuner DVR... record two programs, watch a third (recorded.) However, the signal still goes to the second TV, and the second remote retains controls... so you can watch either TV and have access to ALL recordings on the DVR.
This mode can be switched easily with the touch of a button on the unit.
I've never used the OTA input so I can't really speak to its functionality.
4. I have Vonage for phone service and miss the on=screen caller ID display I used to get with Time Warner digital phone. (I still have Roadrunner and plan to keep it.) Does the DISH HD-DVR receiver offer on-screen caller-ID display? If so, how does one go about hooking up thsi feature? Any wiring needed, etc.?
I'm pretty sure it does have this option, and is probably a simple menu choice, but to be honest, I've never used it. I believe you'd have to have traditional phone service to use it though (the receiver needs to be hooked up to a phone line for updates and PPV stuff.)
