 Post subject: Need to borrow a set of Miata wheels/tires in N. Raleigh
PostPosted: Wed May 21, 2008 8:56 pm
For about an hour, just long enough to mount them to my car and drive to the inspection station and back. The guy wouldn't let my 1.5/32nds Azenis slide, and these are just now getting broken in. :) (it's my dry-weather car, so please no comments).
The closer you are to Leesville and 540, the quicker I can get them back to you. We can pick up an unmounted set, or just to an in-driveway swap - either way.
Honda 4x100's will also work, but I won't be able to swap mine on your car in the interim.
Thanks!
PostPosted: Wed May 21, 2008 9:29 pm
I've got some rubber that you can use. Pm me for more info.
PostPosted: Wed May 21, 2008 9:31 pm
We have a set of wheels with good tires that you are welcome to borrow. They are currently not on a car and so you can pick them up and keep them until the inspection is done.
Charlie
PostPosted: Thu May 22, 2008 8:15 am
Same here my stock wheels are off the car in chapel hill and you are welcome to use them for the inspection
PostPosted: Thu May 22, 2008 8:25 am
Another set available that would fit, in Cary. Azenis with good tread on 16" wheels (the mini's autocross tires). They are off the car right now (runcraps are on it for street use).
PostPosted: Thu May 22, 2008 8:57 am
Dustin,
Also have a set of Miata wheels with Azenis on my tire trailer you can borrow pretty easily - tires have recently passed inspection ... we live less than 10 minutes from Leesville/540 off Carpenter Pond Rd.
FWIW - The Citgo "Quick Lube" at 540 and Leesville is a good place for Inspections
Frank
PostPosted: Thu May 22, 2008 9:26 am
Frank Catena wrote:
Dustin,
Frank
Frank - perfect - that's just minutes from my place. I'm off Norwood. You've got PM.
That Quick Lube is where I've been getting my inspections done. They're certainly "nice" about it, but don't let anything slide.
Thanks everybody!
