 Post subject: Spring rate testing
PostPosted: Wed May 07, 2008 5:40 pm
Anyone know where I could take some springs from a set of coilovers to get the rate measured? Does Mark at Hubcap Heaven do this sort of thing?
91 Miata STT #28
PostPosted: Wed May 07, 2008 5:44 pm
Progressive or linear?
PostPosted: Wed May 07, 2008 7:20 pm
Linear
91 Miata STT #28
PostPosted: Wed May 07, 2008 8:13 pm
For accurate (versus ball park) you might try these guys: http://www.apexvintage.com/home (formerly Krause & England).
For ball park, if the springs aren't too stiff you might be able to do it with known weights and a tape measure, etc.
For ball park, the springs might actually be marked.
Also for ball park, if the motion ratio is VERY close to 1 and you know the approximate corner weights of the car simply measure the spring deflection in the car under load.
PostPosted: Wed May 07, 2008 9:55 pm
^^ thanks!
91 Miata STT #28
PostPosted: Thu May 08, 2008 12:20 am
You can also calculate it and come close:
k = (G*d^4)/(8*n*D^3)
k = constant, pounds of load per inch of deflection
G = modulus of rigidity of spring material, pounds per square inch
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils)
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
G is about 29x10^6 for typical spring steel
From http://www.engineersedge.com/spring_tension_calc_k.htm
