 Post subject: My big project - links fixed
PostPosted: Sun Nov 25, 2007 2:10 pm
Here's what I got done over the holiday weekend.
Getting ready for the next track day - wanted real OP/OT/WT guages, a shift light, and a low OP warning light that goes off before imminent engine grenading.
Other requirements were to not block my sightline, not require cutting my dash, and not looking too ricey :lol:
Got an extra gauge bezel - and constructed this:
Top light is a 10mm blue LED for a shift light, bottom is a 5mm red that I'll hook up to a low OP warning switch.
Lessons learned:
a) minimize the complex curves if you want it to look good
b) black shows every imperfection you thought was gone
c) Bondo sucks - see a) + b)
At some point I'll pull it and clean up some more, and give it a repaint. It is definitely prettier at 5ft than 5in :wink:
Right now the wires are all bundled to a single plug - I still have to do all the under-the hood wiring. Cool thing is I can remove 2 screws and put the stock bezel right back in.
PostPosted: Sun Nov 25, 2007 6:43 pm
I was thinking of doing something like that to add oil pressure and a voltmeter to my ZX3.
PostPosted: Mon Nov 26, 2007 10:05 am
Yeah - I'd seen some 2 gauge pods, and VK sent me a bunch of info on fabrication. 2 gauges fit into that spot pretty easily.
The Summit gauges are pretty deep. With that and the direct viewing angle it had to stick out a bit.
PostPosted: Mon Nov 26, 2007 10:09 am
Good job!!
PostPosted: Mon Nov 26, 2007 5:18 pm
Looks good Kendt. I'll bring the vette over I need some gages installed. :lol:
PostPosted: Mon Nov 26, 2007 5:32 pm
Thanks guys! Gotta give props to VK too for giving me the idea and sending me all kinds of links on how to get it done.
Bernie - I checked and I think a doorknob hole cutter will make just about the right size opening in the dash - let me know when you want to drop off the Vette :lol:
PostPosted: Mon Nov 26, 2007 8:17 pm
BTW - you bringing it to the switchrides AX? I want to hear if you can out-loud Walter 8)
PostPosted: Mon Nov 26, 2007 9:34 pm
It's comming and Gwennies driving.
PostPosted: Mon Nov 26, 2007 10:30 pm
:eek:
PostPosted: Tue Nov 27, 2007 9:05 am
I hear that she LOVES driving the Vette! :lol:
PostPosted: Tue Nov 27, 2007 1:59 pm
clutch, clutch, baby!!!!
PostPosted: Tue Nov 27, 2007 7:29 pm
Got an LS7 clutch to help with putting the power to the rear. and she won't ride the clutch again. :o
PostPosted: Wed Nov 28, 2007 11:34 am
Maybe he could, but Walter isn't going to be there. :cry:
Rubbin' is Racin'
PostPosted: Thu Nov 29, 2007 9:02 am
Ah! i knew this smelled of VK... :D
