Richard Casto wrote:
I got the following ones wrong... a,b,c,d matching gear, the venturi one the fan vs. fan one and the intake cycle one. I think the fan vs. fan one is poorly worded and I stick with my answer, but I know why they said the one they said is correct. I also think that the intake question had two valid answers of which I didn't pick the one they wanted.
So it scored me as a 92%. I think it should have been a 96%
ok, now to bitch about my "wrong" answers...
Fan question...
Their "correct" answer says "The working fan will cause the other fan to rotate in the same direction".
I said it would rotate in the opposite direction. However that is based upon the fact that they have the fans face to face. From the motor perspective they rotate in the opposite direction. But I think they are viewing the rotation along the same axis (regardless of location of motor or point of reference). To avoid confusion, they could have had both fans pointing in the same direction. Either way, the powered fan blades moves the unpowered fan blades and both would rotate the same using the same point of reference.
The intake question...
Their "correct" answer says "from atmospheric pressure pushing it in".
My "wrong" answer was "from suction caused by the piston going down".
Both are right. I understand why they said theirs was the more correct one. They wanted to make the point about atmosphric pressure is pushing the air into the cylinder that has a lower pressure. But from my perspective, it has a lower pressure, because the piston moved and increased the volume for given mass of gas. No piston moving, no pressure differential, nowhere for the atmoshere to push into.
