Took her out today and it was running like a top, until the motor just flat died out on the water (with the family onboard). Drifted in and beached it, fortunately we were only 30 seconds from the beach, and went to work diagnosing. Checked the stupid stuff first ... fuses and circuit breakers fine, cap and wires, ignition switch, battery, controls, etc. When trying to restart I found it would work for a moment after priming, so I suspected the fuel pump and wiring, not ignition. I had a decent toolkit but did not have any electrical diag tools, so I went to the truck and snagged my lighter power plug extension cable (which has an LED showing power), cut the plug, and stripped the bare ends to use it as a 12v test light. Figured out that for some reason the fuel pump must have stopped running. I think it was from some grease/oil on the main fuel pump relay. But to be safe I jumpered the pump direct from the battery and yay! she's alive.
Welcome to inboard motor leisure boat hell.
So now I'm in a hastily repaired POS boat, my first time in the water, faced with the possibility of death by lightning, and I have to tow a boat to the dock at the same time 10000 other people are anxiously trying to get their boats out of the water. Did I mention that the winds are picking up pretty fierce?
Be careful. A freind of mine was killed by lightning trying to get his boat out of the water.
Amazingly we get out OK but I made 2 rookie mistakes. First I was at a bit of an angle pulling on the trailer (did I mention the hurricane force winds?) and chipped a few spots of gelcoat from hitting the trailer at an angle. Then I pulled the boat out without trimming the damn outdrive up, scratching the prop in the process. Won't ever do that again
Try slipping some long(~4ft) pieces of PVC pipe on the metal posts sticking up from just above the tail lights. It gives you something to bounce off of and a reference while your backing the trailer
