No Compromise
Next year, expect a faster, more expensive BMW M3
There are whispers going around that BMW is planning to reveal its fourth-generation M3 in concept-car guise at the Geneva motor show in March before unwrapping the production version at the Frankfurt show in September. So we thought we’d get in early and offer this exclusive peek at the new go-fast version of the 3 Series, on sale in North America in early 2008 as both coupe and convertible.
Our computer-generated images are based on the latest photographs of near-production M3 prototypes spied in Munich in recent weeks, and on information from insiders. Better than ever before, the photos reveal the menacing look of BMW’s new performance hero, set to move up in standing—and price—in line with the competition. It’s not official, but dealer sources suggest the $48,900 sticker price on today’s car will swell to almost $55,000 when the new M3 lands on these shores about a year from now.
You don’t need us to tell you the new car looks mean. Changes over the recently introduced 3 Series include a shapely front bumper incorporating three huge cooling ducts feeding air into the engine bay and to the front brakes, the latter aided by tiny splitter units similar to those on the M5. The classic kidney grille has also been reworked to improve airflow over the hood, which receives a power dome to signal the high-grade artillery beneath it.
The front fenders have been widened to house standard 18-inch wheels. The signature chrome gills are once again nestled behind the wheel arches; the one on the left side draws hot air away from the new car’s delicate in-house-developed electronics package. Farther back, there are unique mirror housings and chunky side sills. At the rear, quad tailpipes punctuate the rear bumper and, as on the M5, a venturi tunnel draws hot air away from the rear differential.
It’s under the hood, though, where the real action is concentrated. In place of the outgoing model’s 3.2-liter inline six cylinder is a new V8. As you might expect, given BMW’s typical engineering thoroughness, the new naturally aspirated unit is not simply a development of BMW’s existing 4.4-liter and 4.8-liter engines. Rather, the M3 receives a cut-down version of the M5’s V10 with a capacity close to 4.0 liters. We say “close” because our sources contend that several capacities were considered, though we hear the one that got the nod retains the same 75.2-mm stroke as the M5’s powerplant.
Shorter but wider than the outgoing third-generation’s inline six, it boasts a 90-degree cylinder bank angle with offset crankpins. Like other BMW M division engines, each cylinder receives its own throttle butterfly to allow the air to be precisely metered for razor-sharp response. Lightweight internals also ensure the M3’s new engine will rev to more than 8000 rpm and, despite its greater output, weigh little more than the decade-old engine it replaces.
With the Audi RS4 packing 420 hp from its 4.2-liter V8, the yet-to-be-unveiled Mercedes-Benz C63 said to get around 450 hp from its enormous 6.3-liter V8, and the upcoming Lexus IS-F touting 400 hp from its 5.0-liter V8, it’s clear BMW’s engine will need more than its existing 333 hp. We’ve heard 415 hp, unofficially. Torque should also increase from today’s 262 lb-ft to more than 300 lb-ft. That should be sufficient to give the new car a 0-to-60-mph acceleration time of around 5.0 seconds, some 0.2 second faster than its predecessor.
What you can be sure of is the new M3 will again receive BMW’s Sequential Manual Gearbox alongside a standard six-speed manual. In its latest guise, as seen in the M5, the SMG offers seven forward gears and a button allows the driver to alter shift aggressiveness. Purists might despise it, but BMW will retain it until its long-awaited double-clutch gearbox comes on stream.
Based around BMW’s new 3 Series coupe (which will be produced, along with the M3, at the German carmaker’s Regensburg plant), the new M3 receives a stiffer floorpan than the outgoing model. It’s also clothed in a larger body, which despite weighing more than before, is said to offer improved front-to-rear weight distribution, thanks in part to a longer wheelbase. Underpinning the new M car is a tuned version of the 3 Series coupe’s MacPherson strut (front) and multilink (rear) suspension fitted with lightweight aluminum components to keep unsprung masses low and response sharp. Given the standard car’s superb poise and balance, the M’s handling and agility should be extraordinary.
It won’t lack grip: Those flared wheel arches house standard 18-inch wheels and tires on the prototypes we’ve spied up to now. Buyers will be able to option the car with larger 19-inch rubber, says an insider involved in the car’s development, which has included BMW’s usual 10,000 kilometers at the Nürburgring.
A further element of the new M3’s dynamic makeup is BMW’s electronically controlled M-differential, so expect lurid oversteer to continue to be served up to those who want it. Like the larger M5, however, BMW has decided against equipping the new M3 with its variable-rate Active Steer system.
[/QUOTE]
