Chuck Frank wrote:
Dustin,
ina makeshift booth like that, wetting down the floor will help keep down the dust. You validated my point about not buying off or no brand spray guns, you get what you pay for, buy the best you can afford, it will be cheaper in the long run.
Yep, had heard about the wetting the floor trick, and would have if we 1) took the time and 2) had enough floor to wet. It's on the list for the next, bigger prject, though.
A good rule of thumb to save a lot of grief later is to decide on what brand and type of paint you want to use, then stick to that brand's products thru the entire process to insure compatability. I.e. don't use one brand of primer, another's sealer, hardware store brand thinner/reducer, still another's paint and yet another brand of clearcoat. Even within a brand be sure that the primer is the right one for the type top coat etc. Paint companies don't make hundreds of products just to confuse us. You may get lucky, but you may also get a paint job that never dries or peels off.
And this is why I went to SW and had them set us up with a "matched set". SW has some nifty "cheat sheets" to help you make choices on which components to use, at what pressure, for which temperature range, etc.....
