 Post subject: Gravana Tuning Turbo Saturn Sky
PostPosted: Wed Nov 01, 2006 8:13 am
Working in conjunction with GM Design, Gravana Tuning – a highly regarded supplier of aftermarket accessories – has pushed the Saturn Sky to the stratosphere with a highly customized concept. The Gravana Tuning Turbo Saturn Sky delivers even more of what roadster buyers want: all-around performance and “stop-dead-in-your-tracks” design.
By adding a Hahn Racecraft 16G intercooled stage 3 turbocharger to the Sky’s 2.4L Ecotec engine, the Gravana Tuning concept returns 348 horsepower and 341 lb.-ft. of torque. Road-hugging handling is enhanced by an adjustable coil-over-shock suspension system that can lower the vehicle by as much as 3 inches – without changing the spring rate. Body roll is virtually non-existent with the addition of 25 mm front and 28 mm rear stabilizer bars. Massive 14-inch drilled and slotted front brake rotors, with four-piston calipers, provide additional stopping power, while a number of functional design elements serve to deliver more cool air into the engine and to extract heat from it.
Outside, the Gravana Tuning Turbo Saturn Sky complements the sleek, crisp and modern lines of the production vehicle, further enhancing its bold, cutting-edge design. Unique front and rear fascias, bodyside panels and rear center exit exhaust – not to mention the OZ Superleggera III 19-inch wheels and Goodyear Eagle F1 tires – give this special Sky a longer, lower, and sleek presence on the road.
Inside, the Gravana Tuning Turbo Saturn Sky features a carbon fiber console and dash inserts. The seat and door panels are finished in Katzkin leather and suede. Seven Boston Acoustics premium speakers and a Visteon eight-channel DSP 360-watt amplifier provide optimal aural enjoyment and complete the interior upgrade.
Vehicle highlights
Powertrain
2.4L Ecotec ported/tuned engine
348 horsepower
Gravana Custom 3-inch downpipe and center exit exhaust
Spec stage 3 clutch kit
Spec billet aluminum flywheel
Suspension
Gravana damping and height-adjustable coil-over-shock suspension
Gravana front and rear stabilizer bars
Wheels/Tires
OZ Superleggera III wheels: 19- x 8.5-in front / 19- x 9.5-in rear
Goodyear Eagle F1 tires: 245/40R19 (front); 285/35R19 (rear)
Fit and installation by Tire Rack
Brakes
Gravana-Wilwood big brake kit
Gravana stainless steel brake lines
Exterior
Gravana/GM Design body kit
Gravana/GM Design rear center exit exhaust tips
Gravana carbon fiber functional hood vent inserts
Gravana carbon fiber rear deck lid
VDI vertical door kit
Interior
Gravana carbon fiber console and dash components
Katzkin leather and suede seat covers and door panels
Audio
Seven Boston Acoustics premium speakers with tweeters and subwoofers
Eight-channel Visteon DSP 360-watt amplifier
Installation performed by J&G Customs
