Mitchell Moore wrote:
Yes Vincent, Dave knows all.
Or at least according to you and Steve
In all seriousness though this guy Dave supposedly has experience doing Vettes. Although I beleive Stablers' was a C4.
The only place I know of in Raleigh is a shop downtown that has worked on Vettes for many years. I think it is called Tigers. Never used them but I have heard them recommended several times.
Quite honestly I don't let anyone work on my car. So far it isn't horribly different from my C4 when it comes to working on it.
Since it appears you're looking at an 02 or newer you don't have to deal with the re-ring issue. Check the diff on each side where the axles connect. There is a cover on each side. They are notorious for leaking on the drivers side. It has been a TSB since 01. Mine only does after lots of abuse on track. But you never find a drop of gear oil on the floor in the garage and the diff never shows low. You just see the stain around the cover.
Since getting my 02 the only thing wrong with it was the original battery. If this car you're looking at has the original battery then check the posts. On mine the positive post all but fell off. That's the only stock thing I had to fix so far. I can't really tell you anything else to be worried about. Just check the basic stuff like any used car you would buy.
