 Post subject: Props to Mike Whitney
PostPosted: Fri Apr 28, 2006 6:26 am
Just a thanks to Mike for helping me with a front sway bar install last night. On my car the install was a little more involved (unbolting subframe, etc) than I wanted to do on jack stands. Mike's lift made it a breeze and we were easily done in less than 2 hours. So thanks Mike, hope you enjoyed the rest of the beer!
The ride home was fine. The new motor mount does give me a lot more vibration, but seemed to reduce some of the clunking I had under harder launches. With the bar up front things have really flattened out. It was still a little too wet to push it too hard, but dry enough that I could tell a difference.
Thanks again!
PostPosted: Fri Apr 28, 2006 7:07 am
So was that why you called and didn't leave me a message yesterday afternoon? :x
Congrats on getting the bar in. Have fun with it. :D
PostPosted: Fri Apr 28, 2006 11:33 am
You're welcome!
(PS - are any other FWD cars this hard to put a bar on? I was pretty amazed at how involved it was. It took us nearly 2 hours, on a lift, with a good set of tools, and only one minor problem. Swaybar sits on top of the subframe and under/behind the steering rack. The engine mount, subframe, steering rack, and exhaust needed to all be loosened/removed so the bar could slip out between the subframe and the unibody rearwards. Guess I'm spoiled by RWD cars where there are usually only 6 bolts and the bar is off.)
PostPosted: Fri Apr 28, 2006 11:56 am
Sponsored by Wal Mart!
Factory procedure on my car is to support the engine and transaxle and then remove the front crossmember. So yeah, it is a bitch on my FWD.
OTOH, I can get the oil pan off in 5 minutes, unlike my RWD cars where it was a major undertaking. Of course, my FWD car has a boxed oil pickup and windage screen from the factory where my previous RWD car had no tray or boxing and a well known reputation for requiring baffling the pan or risking destruction of the rod bearings. :crazy:
Five of one, quarter score of another.
Rich
http://www.v8mongrel.com/
PostPosted: Fri Apr 28, 2006 12:20 pm
Aww, what a cute little car!
on my old mkIV gti it was a pain the first time you did it....you also had to drop the subframe...later installs got easier though
05 MCS
PostPosted: Fri Apr 28, 2006 12:58 pm
On on my Integra and Del Sol you have to take the shift forks off.
David Teague
2015 Lexus IS 250c
1994 Honda Del Sol HS 39
2009 Dodge Journey R/T
http://teaguefamily.us
PostPosted: Fri Apr 28, 2006 6:49 pm
Yes most FWD are that difficult. fortunately not many need a stiffer bar up front they push like a dumptruck already.
PostPosted: Fri Apr 28, 2006 11:00 pm
Hmm, on the Neon it's right there in front of you- 5-10 mins max. Same as on my old Omni. I didn't realize that was unusual. I'll have to look and see what's involved in doing the Mini.
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Fri Apr 28, 2006 11:25 pm
It's easy on the Contour. All that you have to do is support the engine and transaxle and remove the exhaust y-pipe and drop the subframe. Should only take you about ten hours, if you've done it before.
